-   -   XFX 6950 Non-Ref 2G Full fan speed (http://www.hardwarecanucks.com/forum/video-cards/46073-xfx-6950-non-ref-2g-full-fan-speed.html)
raydroid August 31, 2011 01:39 PM
Hello,
I just build a completely new rig with new parts, and when I powered it on I noticed that my video card fan was running at 100%. (I think it's at 100% cause it's really loud!) I installed Windows despite the loudness, and it is still running @ 100% fan speed. Anyone know what the problem can be?
Here are the specs of my build:
Asus P8Z68-V PRO
Intel I52500K
8GB Corsair Vengeance LP
Corsair AX750 PSU
XFX Radeon HD 6950 800MHZ 2GB 5.0GHZ
Thanks!
_dangtx_ August 31, 2011 01:53 PM
install aida64 and check the fan speed.
or xfx's own utility,which shoul probably let you control it as well
you did install drivers right?>
raydroid August 31, 2011 04:28 PM
Hello again,
So I re-installed all the drivers and catalyst. The fan speed is still going at full speed. I then go into the AMD Overdrive mode, and it says my fan speed is at 24% which I do not think is possible... because it's VERY LOUD it says my GPU temp is 34 degrees Celsius. I went into manual fan mode, but even if I change the speed, I can still hear that the fan doesn't change it's RPM.
Could it be because of my motherboard or something to do with it's BIOS?
Thanks,
Ray
_dangtx_ August 31, 2011 04:52 PM
ok so from boot til lthe end of time the fan sounds the same with no change?
overdrive doesnt always work.
whats that utility..trixy or something? i usually let the drivers do there jobs.
