HELP! HI,I Upgraded My computer 3 month ago,but Now my Video Card is Bottlenecking my Intel i5.... I have a 9800 GTX+ SSC,That i'm satisfied but i Want a Direct X 11 capable Card who can do better than mine....Problem...i got 200 Bucks......And just to mention,I'm not a Fan of ATI\AMD:bleh:...Hate ATI Catalyst! Also is it really worth the Dollards??? 3 choice..... GTX 460 GTX 550 GTX 560 Thanks to Helping Me!:biggrin: |
try to score a used one, or a 6950,used of course |
just to mention......I want a card who will handle Skyrim at least at Very High If Not at Ultra at 1680x1050 |
I'm not too sure what that is about - I can extract...
EDIT: ninja'd by OP See if reviews for any of the cards I listed show what you want to play and decide from there. I'm not familiar with ES5's requirements. |
Minimum System Requirements * OS: Windows XP, Vista or Windows 7 * CPU: Core 2 Duo 2.0 GHz or Althon X2 2.0 GHz * RAM: 3 GB * HDD: 15 GB * Graphics: 512 MB card * Sound Card: DirectX 9 Compatible * DirectX: Version 9.0c Recommended System Requirements * OS: Windows XP, Vista or Windows 7 * CPU: Core 2 Quad 3 GHz * RAM: 3 GB * HDD: 15 GB free disk space * Graphics: 512 MB Graphics Memory * Sound Card: DirectX 9 Compatible * DirectX: Version 9.0c Supported Graphics Cards: Minimum – 8800 GT Recommanded – Geforce GTX 460/Radeon 5850 Got my Answer :P THANKS! |
anyone as opinion of Zotac?????? An underbrand of what other brand??? |
I am disappointed that no one has asked the OP what his power supply is, if its a 400W he'd be rather limited. |
System specs. says TX650W. He's fine. |
<table border="0" cellpadding="4" cellspacing="1"><tbody><tr><td class="vbmenu_specs">Motherboard: Asus P8P67 Deluxe</td></tr> <tr><td class="vbmenu_specs">Processor: Intel i5-2500K OC@4.1 Ghz</td></tr> <tr><td class="vbmenu_specs">Memory: 2x2gb Gskill DDR3-1600</td></tr> <tr><td class="vbmenu_specs">Video: EVGA 9800 GTX+ SSC</td></tr> <tr><td class="vbmenu_specs">HDD: 2x Caviar Black 1tb Raid 0</td></tr> <tr><td class="vbmenu_specs">PSU: Corsair TX-650 Watt</td></tr> <tr><td class="vbmenu_specs">Case: Apevia X-Plorer Mid tower case</td></tr> <tr><td class="vbmenu_specs">Sound: Auzentech X-fi Prelude 7.1</td></tr> <tr><td class="vbmenu_specs">Optical: Samsung SH-223BE</td></tr> <tr><td class="vbmenu_specs">Monitor: HP w2207 22in @ 1680x1050</td></tr> <tr><td class="vbmenu_specs">OS: Windows 7 Ultimate</td></tr></tbody></table> |
well until skyrim is out...picking a video card now is a waste of time until the game is out and you know what is needed |
| All times are GMT -7. The time now is 08:39 AM. |
