GTX 470 vs GTX 560Ti I've read so much but heard so many different things I know the main part as far as the review I've read 560Ti Pros : Less wattage, Less heat, DX11 Cons : Not as much ram, Doesn't OC as well? Am I way off here or whats the big difference I would think newer tech just would be better overall to have but curious if I should keep my 470 or trade it for a 560ti (yes I found someone). Thanks! Most review don't use the same specs, etc and had different drivers so curious if anyone has real stats to provide etc... Thanks again! |
560TI all the way. Less RAM, but faster RAM. And (unlike the 470) it OC's like hell!!! :) |
The 470 is a DX11 card as well, I had one. But if someone will trade you straight across or for a small cash difference, I'd do it. |
a 560 is like an oc'ed 460. so a highly clocked 560 will close in to 570/480 territory vram permitting |
Where did you hear the 560 Ti doesn't overclock as well? I was able to get my MSI cards to 1GHz core and 2250 Mhz on memory, allowing to be out perform the 570 where vRam wasn't a concern |
For a straight up trade, thats amazing. Good luck. |
Do it. Faster out of the box, plus all the benefits you listed (though both are DX11 as far as I know), and usually OC great. If its direct swap or plus small amount of cash then do it. |
Thanks guys was able to grab 2 of these Newegg.ca - Galaxy 56NGH6HS4IXZ GeForce GTX 560 Ti (Fermi) 1GB 256-bit DDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card for my 2 of these ASUSTeK Computer Inc. - Graphics Cards- ASUS ENGTX470/2DI/1280MD5 I think I did alright? The guy I got them from says he can OC the 470's higher but I never OC anything so don't matter to me. |
The cards are good (and very sexy) ;) And again, the 560Ti is a much better OC'er than the 470. |
If I could find a guy to trade my GTX 470 for his GTX 560Ti I would. you will see a better performance with them in SLi then the two GTX 470 in SLi IMO you got the better end of the deal. |
| All times are GMT -7. The time now is 02:39 PM. |
