Old August 21, 2011, 02:36 PM
Caldezar's Avatar
OP, I'd stick with a single GPU if I were you. As previously mentioned, your 5870 is no slouch and should still be solid for a while. (Depending on what games you play and what FPS you expect/want) Moving forward, I'd stay away from dual GPU solutions. (Both in sli/XFire and dual GPU cards) Both companies seem to have dropped the ball with multi-card driver support recently. Also consider the cost of a new PSU if you're going multi-gpu. And really, with the excellent performance of both the 580 and the 6970 as single GPU's, it's very difficult to justify spending more money. But, as always, it comes down to individual choice. I spent money on dual 570's recently, then switched to a single 580 and was very happy. (Not to mention, significantly reduced power consumption, noise and heat output.)
*EDIT* - The term 'bottleneck' refers to your computer being only as fast as it's weakest link. Consider data flow as pumping water through a series of pipes, all of various widths. You'll only ever be able to push water through as fast as the smallest pipe allows you to. This is particularly noticeable in a gaming environment, as most games only take advantage of a couple cores and no hyperthreading. (Two thicker pipes are more effective than 4 or 6 smaller ones, since only two will be open at any given time.) So it's all about top-end speed and cache. Although, there's typically a hard-cap on CPU speeds before diminishing returns in games. This, of course, is likely to change in the future as more and more games are being developed for multicore usage.
Old August 21, 2011, 06:18 PM
So you're saying that I shouldn't have any trouble for future games? Right now I'm looking into buying Skyrim. There's no specs out yet but it looks demanding..
Sorry for sounding pesky.
And thanks for the explanation.
God Save the Poutine
Old August 21, 2011, 06:40 PM
depending on resolution and quality settings, your card could be ok or not really. it all depends on those
settings. and the supporting hardware/software , of course.
Old August 21, 2011, 08:04 PM
CloudFire's Avatar
You don't have to worry. The great majority of gaming companies make it so their games can run on a variety of hardware. If an xbox360 can run skyrim with decent settings, then your system is way more than capable. You gotta remember that there are still a bunch of people out there running dual cores with gpu's way less capable than a 5870 and game companies have to keep that in mind to sell a lot of games.
Old August 21, 2011, 09:20 PM
Since I play on a rather small monitor (doesn't bother me) I play at 1280x1024 and I would prefer having the highest settings possible with a tiny bit of AA. Maybe x2 or x4. And I usually go medium in anisotropic filtering and such.
So at least my processor is good for the future?
Old August 21, 2011, 09:30 PM
well at that resolution the 5870 is fine,but i wouldnt be able to sleep at night if my eyes were stucl on anything less than a 23 or 24 or larger with 1080p of course.
at that resolution,again,the cpu will play a large role but you should be ok
get a bigger screen maite, look up a deal.
Old August 21, 2011, 09:36 PM
CloudFire's Avatar
Turn up all your settings to max, a 5870 will handle AA and AF easily, only when you notice slow downs (which won't happen at that reso), then you can turn down settings to improve fps. A 5870 has no problem handling games at 1080p reso with all settings set to high on the great majority of games and your cpu is good for at least another 2-3 years easily so I wouldn't worry about anything.
Even if you do somehow incur slow down in fps, which is highly unlikely at that reso, the order of which things you can turn down are the following: AA -> shadows/lighting -> texture -> everything else. Generally speaking, those are the most taxing settings on fps. AF has virtually no hit on fps at all, even older cards will run at 16x AF no prob.
Old August 21, 2011, 09:45 PM
It doesn't bother me though hahah
Thank you.
And when my comp starts to get outdated what should I focus in upgrading first?
  #19 (permalink)
Old August 21, 2011, 11:38 PM
GT7R's Avatar
The whole system :)
Intel HD Graphics with Graphics Card MoUnit CPU's and Motherboards 4 August 6, 2011 03:54 PM
AMD Launches AMD Radeon HD 6990M - World's Fastest Single Mobile Graphics Processor Sam_Reynolds Press Releases & Tech News 9 July 26, 2011 01:47 PM
AMD Extends Graphics Performance Lead, Launches World's Fastest Graphics Card? Again! FiXT Press Releases & Tech News 2 March 8, 2011 03:32 PM
new to cross fire have a question or two Shadowmeph Video Cards 1 May 5, 2010 10:58 AM
which cheap case to get for a cheap cross fire setup running on air Shadowmeph Cases 22 January 12, 2010 09:03 PM
