<~----> GTX 295 as a PhysX card.. to much ? - Page 2 - Hardware Canucks
Old January 24, 2013, 01:38 AM
Trial Member
Default Only one of the gtx 295 2 gpu's used for physX
I'm upgrading form a EVGA gtx295 co-op to a Asus gtx660ti DCIIT.
Currently I'm thinking of either selling the gtx 295 (and i think its not likely to still get good money for it) or
using it as a PhysX card.
Looking through the settings tough it seems that you can only dedicate one of the two gpu's to physX.
I know one gpu might already be overkill, but for the future is it possible to assign them both to physX?
If not, be warned. Then it does not seem to be worth buying a double gpu card for physX if you can only use one.
Are there any other ways I can use the gtx295 to improve my pc's performance? (utilizing cuda or the memory) B.t.w. I'm not an expert on these matters, so this question might be stupid.
Thanks in advance.
Old January 24, 2013, 05:12 AM
great_big_abyss's Avatar
Thanks in advance.
You could get $100 - $130 for the card on the BST if you tried. It's a fairly popular card with folders. On the other hand, you could keep it, and use it to fold for us.
It would only use one of the cores for Physx, leaving the other one idle. Therefore, as a secondary PhysX card, it really is 'overkill', not just futureproof.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; ASUS GTX650Ti Boost; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; Sapphire HD5870; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old February 2, 2013, 12:27 PM
ern88's Avatar
You are using a 690. I am sure that card is also good enough for physX by itself.
physx card mo' power Video Cards 5 July 30, 2011 10:17 PM
PhysX Card r0k0 Video Cards 11 March 27, 2011 05:27 AM
GTX 460 768 + BFG Physx card Nevakonaza Video Cards 7 October 30, 2010 03:29 PM
Dedicated Physx card with main ATI card? NineLives Video Cards 5 June 27, 2010 07:20 PM
[WTB] Physx Card Dadi_oh Buy/Sell & Trade 12 May 6, 2010 11:57 AM
