Old February 12, 2008, 09:17 PM
yycraven's Avatar
That 8800GT is only a 256MB I thought it was a 512MB card. I also want a 600W OCZ Stealthstreme., but have to wait.
Old February 12, 2008, 10:48 PM
BALISTX's Avatar
No, it's the 512MB version.
XFX GeForce 8800GT Evercool Fan 512MB 600MHZ 1.8GHZ GDDR3 PCI-E DIRECTX10 Video Card - DirectCanada
Old February 13, 2008, 09:22 AM
I saw the same but XT at 234.72$. Is the difference only the overclocking (600-->640 1.8-->1.9)?
XFX GeForce 8800GT XT Evercool Fan 512MB 640MHZ 1.9GHZ GDDR3 PCI-E DIRECTX10 Video Card - DirectCanada
If I buy the non-XT and overclock them, Is it the same card?
Old February 13, 2008, 09:40 AM
BALISTX's Avatar
The only difference is the XT (extreme edition) is overclocked, if you buy the non-XT you could overclock. You could spend the extra $14 and get the XT version and then overclock that to the XXX version.
Old February 13, 2008, 11:08 AM
Could I overclock the non-XT edition to the XXX settings?
Which are the best 8800gt in EVGA and XFX brands?
Old February 13, 2008, 11:46 AM
magictorch's Avatar
That cooler looks almost identical to the one on my older 7950GT...which doesn't work very well on its own.
Old February 13, 2008, 12:05 PM
yycraven's Avatar
Originally Posted by BALISTX View Post
Not saying your wrong, but on there website of XFX its a 256MB.
thats why I could not figure it out if DC had the wrong pic on there site.
XFX - Products GeForce™ 8800 : Models
Old February 13, 2008, 01:36 PM
BALISTX's Avatar
Don't go by the photo of the card. I went by the part number.
PV-T88P-YHF4 - 512MB version
PV-T88P-UHF4 - 256MB version
  #19 (permalink)
Old February 13, 2008, 03:15 PM
yycraven's Avatar
Doh! thats why you put the part number done before, my bad.
Now I will look at part number.
  #20 (permalink)
Old February 13, 2008, 05:05 PM
BALISTX's Avatar
No worries. I think I might go for the XT version for an extra $14.00
XFX GeForce 8800GT XXX alex336 Video Cards 7 November 8, 2007 03:51 PM
