Old August 14, 2011, 04:30 PM
Default High FPS but choppy gameplay with 5770 Crossfire
Hey guys,
I recently installed a second 5770 in my rig, and I've been having a major issue since; when XFire is enabled, my framerate increases but the gameplay itself becomes choppy (for example, when running BFBC2, I get 60-90 FPS on max but it looks more like 30-40). This issue isn't cause by screen tearing, as even when I enable v-sync and/or triple buffering I still get a choppy and stuttering experience.
I've tried doing the following to resolve the issue:
-Uninstalling/reinstalling CCC and GPU drivers
-Defragging my HDD
-Playing around with CCC settings (especially Catalyst AI settings)
-Enabling/disabling V-Sync
-Changing in-game settings
-Updating all drivers on the system
My rig:
-2x HD 5770 1GB @ stock
-Phenom X4 945 @ 3.4
-4GB DDR3 1600MHZ
-640GB WD Black
-64GB Kingston SSD
-BFG 550w PSU
I doubt that the PSU is causing the issue, as I ran a power consumption calculator and it said that my system should only be drawing between 400-450W.
Any solutions for the choppy gameplay?
Thanks
dimre01
Old August 14, 2011, 04:51 PM
bvsbutthd101's Avatar
you can't always trust those PSU calculators
Old August 14, 2011, 05:39 PM
Galcobar's Avatar
Sounds almost like the second card isn't sending its frames to the display, so you're only seeing half the frames. Try re-seating the cards, or with just the second card installed?
Old August 14, 2011, 06:05 PM
Hey man, I tried your suggestion but I'm still getting the same issue. Any other ideas?
Old August 14, 2011, 06:07 PM
swap them around? :)
Old August 14, 2011, 06:21 PM
MacJunky's Avatar
idk much about crossfire so I only ask this because it does not seem to be mentioned at all. Did you mess around with the crossfire bridge(s)? Like, try with none, one alone, the other one alone, two, etc?
Old August 14, 2011, 06:42 PM
lowfat's Avatar
Sounds like micro stuttering to me. It is the reason why I always suggest going w/ a single faster videocard than two lower models crossfired.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old August 14, 2011, 07:00 PM
Kommie986's Avatar
What if the two outperform the one for same/lower price?
Old August 14, 2011, 07:25 PM
I just tried swapping them - still having the same issue.
Old August 14, 2011, 07:51 PM
lowfat's Avatar
It generally will have a higher average framerate. But there are fractions of a second where it is actually lower than a single card. Which causes the micro stutter.
Queen of Dreams WIP
Big Lian Li
Complete
Sapphire AMD Radeon HD 5770 Vapor-X High temps? BFighter Video Cards 1 April 5, 2011 02:52 PM
Upgrade my PC: 4GB DDR3 or xfire 5770 billy New Builds 3 May 31, 2010 07:10 AM
Can I xfire 5770 jnliten Power Supplies 4 May 4, 2010 08:06 PM
PC choppy/laggy issues. stephenc44 Troubleshooting 4 April 14, 2010 06:37 PM
Some blurays are choppy... biff HTPC Systems & Software 8 September 5, 2009 08:03 PM
