Old February 11, 2008, 09:33 PM
Mibs's Avatar
Default NVIDIA system sentintel reporting insufficient power?
Since I installed my 8800GTS I have noticed a couple times at the Windows login screen (XP) that there is a dialog which pops up reporting that my graphics card is recieving insufficient power. Here is an image of that dialog:
http://img.photobucket.com/albums/v2...gpupower-1.jpg
The first time this happened I just ignored it and went to launch a game as usual, only to find the performance was greatly decreased. I tried going into rivatuner to check the clocks, they reported their proper speeds, but I couldnt change them. So I turned off the PC, made sure all connections were secure, and booted again. The dialog wasn't there. This has happened a couple times now since then, and I've been trying to notice patterns of when this happens. One thing I noticed is that when my iPod is plugged in on startup I get this error. So I tried it a couple times without the iPod plugged in and the error doesn't happen. I am fairly confident that the card is seated properly and the pcie power connector is securely fastened.
Does anybody have any suggestions on how I can test this problem? I'm going to reboot again now once with the iPod in and once with it out and post with the results. Thanks for any suggestions.
EDIT: So I just tried booting twice, once with the iPod and once without but I didn't get the error either time. This makes it an even harder problem to solve as it seems to be completely intermittent.
Intel C2D E6750 @ 3.52 GHz // EVGA 680i SLI Rev. A1 (P31) // 4 GB OCZ Platinum 800 MHz 4-4-4-15 // PC P&C Silencer 750 Quad // Antec P180 // EVGA 8800 GTS 512 // Samsung Syncmaster 226bw 22" LCD
WC Loop: D-Tek Fuzion V2 // Danger Den Maze 5 // Swiftech MCP655 // Swiftech MicroRes // Thermochill PA 120.2 + 4 x Noctua NF-P12
Last edited by Mibs; February 11, 2008 at 09:40 PM. Reason: to add results of test.
Old February 11, 2008, 10:52 PM
Cptn Vortex's Avatar
The power bug in a PC power and cooling unit? Uh oh! Refer to this thread, and a ton more like it! Corsair PSU...Not enough power?
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old February 12, 2008, 12:32 AM
WTF please tell me you don't have a PC P&P and its bugged :(
Old March 7, 2008, 07:23 AM
Sorry for the cross posting. Since people might be watching one of several threads that touch on the same problem, I figured it would be OK to post this important update in each of them:
Posted on the EVGA forums:
ORIGINAL: EVGATech_JacobF
For anyone that is experiencing the "Low Power Warning Message"
Please use the following driver:
EVGA | Support | 8 Series Driver Download
-Jacob
These are the 169.44 drivers that are supposed to resolve this issue. I haven't had a chance to test them myself yet.
Old March 14, 2008, 04:16 AM
bod bod is offline
I have just tried these drivers and they did indeed fix the problem!!!
My MSI 8800GT now works with my Antec Quattro 1000w
TFFT
Nvidia or ATI Witwikki Video Cards 11 February 6, 2008 06:38 PM
ati vs Nvidia Rapid-X Video Cards 14 January 26, 2008 11:22 AM
PC Perspective reviews 1000W BFG Tech PC System power supply Supergrover Reviews & Articles from the Web 0 February 22, 2007 09:40 PM
