Old August 11, 2011, 03:04 PM
aristhrottle's Avatar
Default 560 Ti Hawk alarmingly loud when gaming
So my 560 Ti Hawk gets very loud when I play Total War: Shogun 2. Temperatures hover around 77 degrees and the fan speed stays at around 70%, which sounds like being in a room full of industrial stand mixers trying to mix a bowl of quickly hardening cement. This is on stock voltages and clocks, in a 650D.
What is weird is that if I run Furmark or Kombustor, even for extended periods of time, the card never gets that hot and the fans don't spin that fast. I tried checking out some review sites to compare temps and they all seem to have much lower load temps than I'm getting. One review site even had load temps of 54 degrees overclocked, which is absolute nonsense because according to Afterburner I'm sitting around 50 degrees idle.
Is my card defective or is this normal?
"CFL receiver Sylvain Girard announced his retirement today. His party will be held at The Keg, right after he and some other players finish their shifts there." - Air Farce
Old August 11, 2011, 03:48 PM
650D's are hotboxes... could be your issue, more likely you need to update your drivers.
Also you could give MSI a call and see what they say, if they wont RMA it for you reseat the cooler with some better thermal paste.
Old August 11, 2011, 05:36 PM
Those are horrible temperatures for that card. I have the MSI Frozr2 and I keep the fan locked at 40% in MSI Afterburner. I don't see temps ever go over ~70C. The big difference between you and I is that I'm using a HAF 912.
Old August 12, 2011, 09:39 AM
So I called MSI and they told me that they won't do anything unless the card artifacts. They also told me that my temps are normal, which I find a bit disappointing since lower heat and noise is the reason why I paid extra for this card.
Old August 12, 2011, 10:12 AM
Reseat the cooler and retest in open air, if your temps are still that high, find an excuse to do a direct RMA or attempt a direct RMA.
Supercom/Daiwa handle the majority of MSI RMA's in Canada not MSI themselves and are generally eons better than MSI in terms of customer service. Do whatever you can to deal with them directly. In my recent experience MSI tech support is still rude and unpleasant to deal with despite being slightly better in recent years. If you don't have a bulletproof complaint laid out in a professional manner, they will give you plenty of crap.
Old August 15, 2011, 11:16 AM
Does reseating the cooler void the warranty?
Old August 15, 2011, 12:18 PM
i would rather manually control the fan than reseat the cooler.
with msi,perhaps.
Old August 15, 2011, 01:13 PM
GT7R's Avatar
Try to look carefully, whether there are any seals/stickers which will be damaged while disassembling the cooler. If not - they won't be able to prove you did anything, just do it clean and carefully :)
Old August 16, 2011, 05:33 PM
All right so I decided to send an e-mail to one of those people who leaves their contact in the Manufacturer Response section of NewEgg reviews, even though I didn't buy my card from NewEgg nor did I write a review. I told him the exact same thing I said over the phone. He immediately agreed that my card was faulty and offered me an advanced replacement for my RMA. I guess large sample variation extends to more than just their cards!
Old October 31, 2011, 10:23 AM
Did the replacement card they send you fair better? I'm curious to know since my MSI GTX560 Hawk is also running quite hot. More so than yours even. I'm at around 40 degrees C at idle but up to 90 degrees C under load and even hotter when run in SLI with my Gigabyte card. I expect the card to run hotter in sli but it's nearly 30 degrees hotter than my GB Gtx 560Ti SOC.
MSI 560 Hawk vs GB 560 SOC vs MSI 6950 TF3 -Clive- Video Cards 13 June 16, 2011 11:51 AM
Paccus Hawk Joystick. Slik Peripherals 0 May 11, 2011 10:17 AM
MSI N560GTX-Ti Hawk grifter11 Video Cards 5 April 14, 2011 05:26 PM
NGTX460 Hawk 1g Your_friendly_gamer Troubleshooting 7 March 5, 2011 06:11 PM
How loud is too loud for fans? Liu Kang Air Cooling 40 April 5, 2009 10:11 PM
