Old August 8, 2011, 10:22 AM
Default reference 6950's for water
Back when the 6950's first came out i picked up a reference 2gb card. Thinking I would be satisfied I never bothered considering crossfire. Now I find myself going for crossfire (now) and eventual water loop (over the next 2 months). Now my question is are there any reference design pcb card still out there? I know none of the available cards have stock coolers but do any have the original pcb? I dont really care much for the unlock as i dont think most if any of the cards out now will I just want a card I can fit a f/c block to. I would be purchasing here in Ontario. Thanks for your help:)
Old August 8, 2011, 01:32 PM
Keltron 3030's Avatar
So you have the first version of the 6950, correct? the version that was physically identical to the 6970? if this the case, then no, there is a new revision that has been in production for quite some time now. you might get lucky thou.....
FFFFFFFUUUUUUUUUUUU-
Old August 8, 2011, 10:02 PM
Yep it's the first version of the card thats identical to 6970's but was hoping some manufacturer might of stuck with the original pcb design.
Guess I'll have to go with a universal block or just leave it and put my other card underwater if the new coolers are quiet enough. I hope this doesn't look too hideous.
Old August 9, 2011, 12:46 AM
Actually, most well known block manufacturers (EK, DD, Koolance) got FC-WB for the new 6950 (V2), if that's what you were wondering.
Old August 9, 2011, 09:32 AM
I found through EK's configurator that they have a f/c block for the powercolor AX6950's which is good. Now I just hope they get some in stock at a certain local Canadian chain before payday.
[FS] Noppoo Choc Mini (Browns) Vittra Buy/Sell & Trade 25 August 11, 2011 07:35 AM
[FS] ASUS 5870 Reference & XFX 5850BE Reference & LED 23" Monitor tragd Buy/Sell & Trade 4 August 10, 2011 09:36 AM
Water block for 6950? Varroa Water Cooling 14 July 30, 2011 11:22 AM
XFX 6950 2GB v1.2 (reference) still unlockable? Phill Video Cards 37 April 14, 2011 11:35 AM
Non-Reference 6950/6970? CMetaphor Video Cards 22 April 8, 2011 04:13 AM
