Old August 6, 2011, 12:49 PM
Default OC HELP for AFTERBURNER: MSI N240GT-MD1G/D5 GT240 1GB R
I added this card a couple months back and just got around to looking into the overclock.
It is advertised that i could overclock for 30% increase in performance.
I tried searching the best settings to use in afterburner but wasnt successful.
Would anyone have any suggested settings for this card?
ps: Im using it in an pre-built hp athlon x2 5200+ with 3 gb ram
thanks
Old August 6, 2011, 01:27 PM
first of all, oc'ing it wont do much in heavy games.
in lighter/older games,perhaps
secondly,try precision,by evga. bring up the shaders while running firmark,
once you find a stable max at a certain fan setting(unless passive) drop 5-10 mhz and save your settings
then worry about the core. dont touch ram.
Old August 6, 2011, 05:28 PM
supaflyx3's Avatar
you will not a 30% increase, maybe 5-10%
and bump up the shader and core clocks by 10mhz at a time, and run furmark for 5 mins to see if there isnt any artifacts (weird lines and blocks) if there isnt, bump up again, and continue. Expect to spend at least an hour or two tweaking.
Old August 6, 2011, 10:58 PM
Is there any other way to proiceed? Would there be no standard for OC this particular card... like an average of all users? or does every card have different OC possibility?
Old August 7, 2011, 12:12 AM
ps im looking to improve sc2 fps
Old August 7, 2011, 01:03 AM
MARSTG's Avatar
quit oc'ing that card and get a more powerful one. look for a 9800gt/9800gtx/gts 250 you should find them around 50-60$ on craigslist or kijiji locally in MTL. your power supply has a 6 pin connector?
Old August 7, 2011, 01:35 AM
supaflyx3's Avatar
I have a gts250 for sale if you're interested :p
Old August 7, 2011, 06:25 AM
MARSTG's Avatar
and i'll upgrade it for free with a gts 250 if you fold in my name when you don't game. :)
MSI Afterburner - how to unlock vram slider? Dead Things Overclocking, Tweaking and Benchmarking 5 February 15, 2011 01:35 PM
[FS] Two MSI Cyclone 460 1gb jibz Buy/Sell & Trade 6 February 11, 2011 12:04 PM
MSI afterburner Overvolt martin_metal_88 Overclocking, Tweaking and Benchmarking 17 September 26, 2010 02:58 PM
MSI Launches N240GT Supporting Over-Voltage, Overclocking Support by Afterburner Software FiXT Press Releases & Tech News 0 November 17, 2009 02:07 PM
MSI Afterburner?? sswilson Video Cards 0 October 20, 2009 12:20 PM
