Old August 3, 2011, 08:49 PM
BVickery's Avatar
Default Vid Card Question
I'm an avid gamer. Right now my GTX260 (216 cores) is starting to show its age some, and given that new architecture is coming out soon, figured I'd grab a card then.
My biggest question is which one, assuming nVidia and AMD keep the relative same numbering structure.
I have about a 20" LCD w/ 1680x1050 resolution.
I really like playing with a lot of the eye candy turned up, but also don't want to buy a card that is overkill.
Old August 3, 2011, 08:53 PM
right now people wil ltell you a 768 megger gtx 460 for that rez.
dx11,ok on the psu,not very noisy :)
which card for 'then' ? well we dont know yet,as 'then;' hasnt happened yet. :)
Old August 3, 2011, 09:00 PM
BVickery's Avatar
Oh, did forget to mention I do have a 650W Corsair PSU.
Old August 3, 2011, 09:02 PM
BVickery's Avatar
Actually, you helped out greatly.
I figured the x70/x80 from nVidia would be just overkill on my system. So figured the x60 from nVidia or the xx50 for AMD would be ideal, unless I could get the upper level cards dirt cheap (IE Black Friday, Cyber Monday type deals).
supaflyx3's Avatar
+1 for 768mb 460, i have one and love it
Old August 3, 2011, 11:07 PM
Caldezar's Avatar
What games are you playing? Even at that low a res, I wouldn't want a 460 for running Metro 2033.
My thought is; if you're buying new hardware to upgrade a previous gen, why buy another previous gen? For about $190 you can at least grab a 560ti for excellent performance, larger buffer and o/c potential. (less if you find a good sale.) Or grab a 6950 used for a good price for the best option. I think there's two or three listed in bst at the moment.
Old August 4, 2011, 05:20 AM
Soultribunal's Avatar
If you don't plan on getting a bigger monitor anytime soon then a 460 would suffice. And you can get them new dirt cheap.
If you do want to spend a little more and perhaps go 1900x1050 then opt instead for the 560TI. I would normally suggest something on ATI's side but their Driver issues have forced myself and a few of my friends to not use their current generation..
ST
www.realhardwarereviews.com
Old August 4, 2011, 06:41 AM
Caldezar's Avatar
A 460 will cost you $140 + tax ($155'ish). Or you could spend $200 flat with Arinoth's bst and get one of the better 560ti's available. Just sayin...
Old August 31, 2011, 02:13 AM
BVickery's Avatar
I do plan to move to a larger monitor (24" 1920x1080), and thinking maybe a 6870
Pricing right now for a 460 is in the $150-180 market (including some MIR)
The market for the 6870 is $159-199 w/ MIR
I don't mind not having the latest gen card, my finances can't afford it.
Old August 31, 2011, 05:09 AM
GT7R's Avatar
A 560ti will smash the 6870. And will OC better.
Need to upgrade my second vid card biff Video Cards 1 February 26, 2010 02:06 PM
what vid card should I get? omgwtf Video Cards 17 December 15, 2008 06:34 PM
Thinking of next vid card biff Video Cards 14 December 2, 2008 09:24 PM
new vid card cmac79 Video Cards 3 July 29, 2008 11:39 AM
which cheapo vid card? philmar Video Cards 6 May 25, 2007 03:46 AM
