Old July 29, 2011, 11:23 AM
Trial Member
Default 6950 crossfire 16x/x4 bad?
So im thinking of going crossfire 6950's but the only thing that is stopping me is that my motherboard only supports 16x/x4 crossfire..so what i want to know is how much performance will i lose and is it worth it?im gaming at 1600x900 yes,yes,i know overkill..I KNOW!!
Old July 29, 2011, 12:56 PM
Shadowmeph's Avatar
I wouldn't cross fire x16 /x 4 only x8 /x8 and above
Old July 29, 2011, 01:08 PM
odis172's Avatar
At that low resolution, I wouldn't recommend it as a decent upgrade at all. If you plan on upping your resolution, thats a different story.
According to toms, the 6950 at x4 will get anywhere from 25 to 50% less performance then at x16, depending on resolution. What motherboard and cpu are you using?
http://www.tomshardware.com/reviews/...ce,2887-6.html
Also, make sure you board has a x16 physical slot wired for x4 electrical, and not just a x4 physical slot, otherwise the card won't fit.
You may want to check out some pcie scaling articles for further reading:
*Asus P8P67 (PCIe 16x/4x) vs. Asus P8P67 Deluxe (PCIe 8x/8x) - HD6950s in CF tested* - AnandTech Forums
GTX 480 SLI x16/x16 vs. x4/x4 - GTX 480 SLI PCIe Bandwidth Perf. - x16/x16 vs. x4/x4 | [H]ard|OCP
http://www.tomshardware.com/reviews/...x4,2696-3.html
Laptop: Lenovo T420 - Core i5 2520 - 8GB DDR3
Server: 2 xeon E5530 - Asus Z8N-D6 - 12GB DDR3 - 8x 500GB raid 50 - Perc 6/i - Compucase RA448A00
Old July 29, 2011, 01:51 PM
Dr_BenD_over's Avatar
It was bad when I tried it with 3870's years ago. (and a pair of 6800GS's long before that )
If it's stupid and it works, it isn't stupid.
Old July 29, 2011, 05:23 PM
Silvgearx's Avatar
No such thing as overkill. Using 16x/x4 for crossfire is pure stupidity.
Let me put it this way, why would you pay for 2 expensive gpu and cheap out on a board that can't bring out the cards true potential?
You probably won't lose performance depending on the game, but extremely small gain using 16x+x4 PCIE lanes.
Time to upgrade motherboard board, or go 6990.
Old July 29, 2011, 06:17 PM
Soultribunal's Avatar
You'll probably net better overall performance going with two lesser cards.
I would not suggest using what you want to use on a board that only offers those lanes, you would really be choking the second card.
ST
Old July 29, 2011, 07:02 PM
just get one 6950 and see what gives.
welcome aboard btw
Old August 1, 2011, 03:02 PM
NI3 NI3 is offline
[IMG]http://www.************/images/articles/1282682382IabXi1rEcG_1_4_l.gif[/IMG]
[IMG]http://www.************/images/articles/1282682382IabXi1rEcG_1_5_l.gif[/IMG]
http://www.************/article/2010/...x16x16_vs_x4x4
Old August 1, 2011, 05:40 PM
Silvgearx's Avatar
Thumbs down
Originally Posted by NI3 View Post
That is done on a X58.
Most mother board that support X16 + X4 are budget board , the X4 lane been controlled by the chipset. What good will do you by adding extra latency between cpu and gpu? A good headache from the Micro Stuttering.
But don't take my words for it, best way to find out is to experiment.
A much much better scaling review.
AMD Radeon HD 5870 PCI-Express Scaling Review - Page 1/26 | techPowerUp
[FS] XFX 6950 2GB stuck at 500mhz, selling it cheaper, sold mckchun Buy/Sell & Trade 11 December 21, 2011 05:02 AM
6950 Crossfire 1gb tianfeng Video Cards 2 July 2, 2011 01:10 AM
Crissfire - 8X, 16X... GT7R Video Cards 11 October 16, 2010 06:45 AM
bad headset or bad onboard sound? Remoth Audio 8 May 24, 2010 09:38 PM
Need help looking for a board that will run Crossfire at dual 16x mode Gameplaywarrior CPU's and Motherboards 4 July 9, 2009 01:44 PM
