-   -   GTX 460 sli PSU? (http://www.hardwarecanucks.com/forum/video-cards/45121-gtx-460-sli-psu.html)
KSiG July 23, 2011 01:59 AM
GTX 460 sli PSU?
Im going to be running two GTX 460 1GB in sli for Battlefield 3 Is a 850watt Psu enough power or should i go with the 1000watt?
jdm89 July 23, 2011 02:08 AM
850watt is more than enough to power 460's in sli
Apathetik July 23, 2011 02:25 AM
lol 850 is SUCH overkill, its not even funny. ok a bit funny.
http://www.guru3d.com/article/geforc...-sli-review/15
da_bradler July 23, 2011 02:32 AM
I have 750w with the 460s over clocked to 800mhz and I have no issues, I doubt I'm much over 600w.
KSiG July 23, 2011 02:33 AM
What did you overclock them with?
Bond007 July 23, 2011 04:49 AM
850w is more then enough...assuming it's not a cheapy 850w. What PSU is it?
Sagath July 23, 2011 07:30 AM
Probably MSI Afterburner, with a bios mod.
If you're over 600w there is something terribly wrong, or you're extremely overclocked on both your CPU and GPU cores. From memory my i7 920 @ 4.2 and 2x460's @900mhz+ (bios modded) were pulling about 460-480 from the wall while folding on everything.
yycraven July 23, 2011 10:32 AM
Corsair HX650 should be enough to run both cards, from your specs you have a 1000W PSU now so why you worrying about PSU.
KSiG July 23, 2011 11:32 PM
I have two psu
Coach July 24, 2011 11:41 AM
FWIW my other rig has two gtx 460 in SLI with a HX620 and IMHO that is plenty. A quality 600W should and will not have any issues, Anything more than that is just gravy.
