Originally Posted by Arinoth Ah another fellow multiple-monitor gamer, we have our own little 'support' thread for whenever you feel like sharing your experiences, set up or annoyances.
I would recommend getting a better power supply, and to give you a bit more head room I'd recommend a 850W power supply. Myself I am using Corsair's 850W Modular power supply, once going modular (like going multiple monitor gaming) I'd never go back due to the fact you can do a lot better cable management with a modular psu as you only plug in the cables you need.
As regards to the graphic cards, the 6950s would/could do the trick, however I'd recommend above anything if you are set on those cards to get the 2GB versions over the 1GB. Not because you could potentially flash them to 6970s, mainly for the fact that even though you are running 2 cards, each card cannot share the memory with the other one, meaning your maximum memory buffer is limited to whatever the onboard graphics card memory is. Some games, such as Dragon Age II require quite a bit of memory and you can lose out on additional performance as you increase settings towards max as the two gpus can only share so much between the two of them due to the limited onboard memory (of 1GB, speaking from my 560 Ti experience personally here). |
Wow I didn't know this nice to know for my future build :)
