Old July 5, 2011, 01:04 PM
Trial Member
Default I cant remove my GTX 580!!!!
i have 2 gtx 580s in sli on a gigabyte ga-x58 ud5 mobo, and i want to remove one of the cards, the problem is, they seem to be locked into place, even when i put alot of force into pulling it. i have never had a problem reomoving a pci-e card ever plz help if you know what i can do to get this card out.
Old July 5, 2011, 01:05 PM
Lpfan4ever's Avatar
There's white clips at the end of the PCI-e slot itself. You have to push them downwards towards the bottom of the motherboard and pull at the same time.
Originally Posted by encorp
Code:
<firebane> slightly used
Old July 5, 2011, 01:07 PM
and or break them after wards so the cards slide out easy,too easy might i add. do it at your own risk,of course :)
and welcome aboard!
Old July 5, 2011, 01:17 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Breaking those white tabs could negate any warranty on the board.
But as was already stated, push the white tab down while pulling out the card.
Old July 5, 2011, 01:21 PM
i know, but ive seen 2 dead(physically) mobos and one card or two the past couple months
from the exact cause as above :)
at least this guy asked before pulling stronger. one guy killed his classy and dual 570's(he tried with the puter on lol)
Old July 10, 2011, 01:47 PM
Caldezar's Avatar
Or... in the case of slot 1 and 5, pull the extended tap 'up' and pull the card at the same time...
*Edit* But I assume this has been taken care of since it was posted 5 days ago. Didn't even notice.
martin_metal_88's Avatar
Removed a lot of PCI-e but can't figure out how to remove card from PCI-e...yes...
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
GTX 580+GTX 275 Dedicated PhysX Rocyaic Video Cards 6 June 15, 2011 11:13 PM
Best GTX 580? BFighter Video Cards 7 April 19, 2011 01:22 PM
GTX 580 Value? Shozzking Video Cards 2 March 25, 2011 04:24 PM
Safely Remove Hardware Can Remove EVERYTHING geokilla O/S's, Drivers & General Software 29 August 4, 2010 11:25 AM
