Old July 1, 2011, 06:39 PM
tianfeng's Avatar
Default 6950 Crossfire 1gb
So I am thinking about going crossfire but the card I have now is a 6950 1gb. Should I go 2gb for the second card or stick with 2 1gb's? If I crossfire the 2gb with the 1gb it will be only be 1gb so what would be the best way to go?
Old July 1, 2011, 07:34 PM
is this for single monitor use?
the 1 gigs should be fine.
i might be wrong,but i think you need two of the same? although in theory 1+2 gigers should
be able to crossfire with each other and 6970 as well due to the core being of the same family...:)
Old July 2, 2011, 01:10 AM
Apparently 1 and 2 gb cards will crossfire but you will only be using 1 gb on the 2gb card so it's kind of pointless.
6950 1GB version waterblock? oksir Water Cooling 7 July 31, 2011 12:43 PM
AMD RADEON HD 6950 1GB GDDRS- Problems----Fixed eskyy Video Cards 9 June 10, 2011 11:53 PM
AMD Radeon HD 6950 1GB Review Comment Thread SKYMTL Video Cards 17 January 31, 2011 05:14 PM
HD 6870 vs upcoming HD 6950 1gb RedTauren Video Cards 2 January 3, 2011 11:02 AM
