-   Video Cards (https://www.hardwarecanucks.com/forum/video-cards/)
-   -   palit 1 gig 8800 fit my ASUS made IPIBL-LA (Berkeley) mobo? (https://www.hardwarecanucks.com/forum/video-cards/4461-palit-1-gig-8800-fit-my-asus-made-ipibl-la-berkeley-mobo.html)
Reddog February 5, 2008 06:58 PM
Ive got a HP premade system (got it cheap with a gift card) but the onboard graphics are lame.
I was wondering if a Palit 1 gig 8800 GT would fit my single slot PCIE mobo? Its an ASUS made IPIBL-LA (Berkeley)...
Now I've been told by some that the fan on the card may get in the way, but a tech (from a local store) told me the only problem would be the actual length of the card... I think I can move some stuff around so length won't be an issue but I ain't so sure bout the width, the cooling fan is awful thick...
Anyone have any cloo?
Should I just stick with an ASUS single slot 512 MB 8800 GT card? I know it fits...
Oh yeah any recommends on a power supply? The HP one is only rated for 300 watts ...
ArrOOoo, Reddog
belgolas February 5, 2008 07:23 PM
don't get the 1 gig card get the 512mb card cause the 1 gig card is slightly SLOWER than the 512mb card.
Reddog February 6, 2008 06:01 PM
Really?
I saw the Palit ratings saying that it was faster on games like Crysis?
You don't think the extra 20.00 dollars is worth it for the cooling?
ArrOOoo!
vertex112 February 7, 2008 03:29 PM
There is no way you are going to need to use 1gb of vram. Games usually max out at below 512mb unless you are running a very high res like 1920x1200 and over. Belgolas is right about the 1gb being slightly slower than the 512mb. That is because the memory controler doesnt have to work as hard with the lesser amounts of memory. And for the cooling option, the 8800GT is a fairly cool card. Meaning it doesnt generate that much heat, hence why nvidia stuck a single slotter there in the first place. And im not sure about the PSU, I know I would not use a 300watt PSU for a 8800 series card, maby a midrange card, but not an 88. So I would reccomend you upgrade to a beefier psu.
belgolas February 7, 2008 04:07 PM
for cooling sure but if you don't over clock it then you might not need the extra cooling. 300 watt might be enough but it is always good to be safe.
b1lk1 February 7, 2008 04:11 PM
No no no no no no no. The 1GB card is senseless since the 256-bit memory bus effectively kills the usefulness of 1GB. The card will never ever get the chance to use more than 512MB of that memory, and it is most certainly timed slower than the 512MB cards memory. The 1GB card is pure marketing hype. Do not get it it is not worth it even for $1 more.
Your power supply is gonna croak under the load and probably kill your whole system too. That crappy 300W unit is probably capable of 200W sustained load for any length of time. Don't waste your time putting a high performance card in a low performance PC. Save your dough and build your own.
vertex112 February 7, 2008 04:53 PM
That is sort of harsh if he cannot afford to build his own. anyways you can still get a midrange card like the ATI 3850 which should easily run on a 300watt psu.
Reddog September 6, 2008 05:43 PM
Hi guys I ended up building a new system and my wife got the other one...
Thanks for the input!
ArrrOOOooo!
belgolas September 6, 2008 08:55 PM
Hows your rig?
carhead22000 October 2, 2008 01:44 PM
palit
well i dissagree,i have 2 palits 1 gig running in sli,and don,t listen about benches either.this card kicks ass.it plays crysis flat out all the way maxed!!!!same with new crysis warhead.do some reading most cards won,t.my friends card benches way higher then mine and his shits the bed on crysis.theres more to cards now then benching.shaders and stuff are big for hungry games.i would def buy one foir gaming bud.:thumb:
