View Poll Results: Which card is better?
XFX HD Radeon 6950 1g 2 22.22%
MSI gtx 560-ti twin frozr 7 77.78%
Voters: 9. You may not vote on this poll
Old June 25, 2011, 01:59 AM
Default xfx 6950 1g or msi 560 ti twin frozr?
for my nect comming pc i am planning on getting either one of these graphic cards. ive heard good things about each other and bad things to. but overall i think they are good for the price they are.
i will be purchasing these from ncix for a decent pricing,
XFX Radeon HD 6950 830MHZ 1GB 5.2GHZ: for $295
or
MSI GeForce GTX 560 Ti Twin Frozr II 822MHZ 1024MB: for $245
or:
MSI GeForce GTX 560 Ti Hawk OC 950MHZ 1GB: $280
which card do you think is better for the price they are at. i might be doing some overclocking with my graphics card but it is highly unlikely. so which one of these are better? in the future as games require more, i will be buying an aditional on of these to either sli or xfire. so which is better? i and since i am going to upgrade, should i get a 750w power supply or a 850?
system specs:
Intel Core i5 2500K Quad Core Unlocked Processor LGA1155 3.3GHZ Sandy Bridge 6MB
Corsair Cooling Hydro Series H50 High Performance CPU Cooler System LGA1155
ASUS P8P67 Pro REV3.0 ATX P67 LGA1155 DDR3 3PCI-E16 2PCI-E1 2PCI Sandy Bridge B3 Motherboard
Mushkin Enhanced Silverline Stiletto 8GB 2X4GB PC3-10666 DDR3-1333 9-9-9-24 Dual Channel Memory
XFX Radeon HD 6950 830MHZ 1GB 5.2GHZ GDDR5 PCI-E 2XDVI HDMI 2x Mini DisplayPort Video Card
Corsair Obsidian Series 650D
Corsair TX850W 850W CMPSU-850TX 12V 70A 24PIN ATX Active PFC 140M Fan Power Supply
or
Corsair TX750 V2 750W ATX 12V Single Rail 60A 24PIN ATX Power Supply Active PFC 80PLUS Bronze
Old June 25, 2011, 08:44 AM
6950 but find a better deal.
either corsair 750/850 psu will be mighty fine :)
btw youre spending a big chunk on the case, look at the cm 912,lots of room,very cheap!
edit both psus wayy overkill for single card. the 850 is overkill for dual too :p
Old June 25, 2011, 10:54 AM
Stick with the Obsidian 650D, it's a great case.
I had purchased a Haf 922 before it and the quality was so cheap (I tried 3 cases) and I couldn't take the crapmanship, so I paid the extra and bought the 650D.
Amazing case, just make sure it's the newer revision which has the linear fan controller (-1 at the end of the product code on the UPC).
Tags
hd6950 , msi gtx 560 ti twin frozr
MSI 560 Hawk vs GB 560 SOC vs MSI 6950 TF3 -Clive- Video Cards 13 June 16, 2011 11:51 AM
MSI Radeon HD 6950 Twin Frozr III BFighter Video Cards 3 May 1, 2011 10:07 AM
MSI GTX 560-Ti/570 Twin Frozr SLI Aeshma Video Cards 10 April 26, 2011 10:30 PM
MSI 6950 2gb Twin-Frozr 3...worth it? Socrates_Johnston Video Cards 15 April 7, 2011 09:11 PM
XFX Radeon HD 6950 XXX 1GB or MSI GTX 560 TI ? Rush Video Cards 17 March 26, 2011 07:30 PM
