Old June 26, 2011, 12:22 PM
The overclocks listed in this section were achieved with the default fan and voltage settings as defined in the VGA BIOS.
basically they are only changing the clocks without touching the voltage...which is necessary for a big OC, I've seen the ASUS run 24/7 on 950mhz core (it could even reach 1ghz while staying under 75C furmark but there was no actual gain in performance: this is the limit of the GPU in other words not the card...) every GPU is different and if you win at the silicon lottery 1ghz+ should be very doable!
It has been a long known fact that overclocking headroom increases as soon as you increase the operating voltage.
You can see at only 1.1v they hit 900mhz:
...personally reached 950mhz @ 1.15v which is quite similar to their results but my temps where quite a bit lower, maybe i have much better airflow/ambient temps...
Edit: just realized at stock settings they are getting high 60s while I was getting mid 50s so that must be it, either they live in Hawaii or they are doing their testing in a Corsair hotbox!
Old June 26, 2011, 08:40 PM
Awesome response man! I see what you mean now. Although I do have a Corsair, it is the new 600t Special edition so i'm not too worried about temps.. if it ever becomes a problem i can always drop 6 120mm fans into it hehe.
Old June 29, 2011, 08:06 AM
with the Asus Sabertooth p67 board would SLI with two Asus cards be possible?
Old June 29, 2011, 10:29 AM
yes but u will need a case with EIGHT expansion slots as the bottom card will be hanging off the edge of the motherboard (the 600T does have 8 expansion slots).
Old July 5, 2011, 05:12 PM
Go for the MSI 570 GTX! I have one to sell as i cant put a water block on it. 2 weeks old. Dam MSI changed the chip lay out.
GTX 570 HMFlol Video Cards 9 April 3, 2011 08:39 PM
Gtx 560 Ti vs Gtx 570 Hexofire Video Cards 7 February 21, 2011 12:07 PM
[WTB] Looking for: GTX 570 THS Buy/Sell & Trade 2 December 29, 2010 05:24 AM
GTX 570, GTX 460 1GB SLI or AMD alternative(s)? Zak_M Video Cards 4 December 18, 2010 06:43 AM
Rumor of GTX 570 and GTX 560 on its way vohiep84 Rumor Mill 15 November 20, 2010 08:43 AM
