Old June 22, 2011, 06:51 PM
Default HELP!
Im looking for a graphics card that can run Battlefield bad company 2 at max settings at 60fps my budget is $300
i have been looking for 3 staight hours can someone help me. Thanks.
Old June 22, 2011, 06:55 PM
Perineum's Avatar
What resolution are you playing at? For most resolutions a 560 should do it, I would think.
My 260 does fine.
Old June 22, 2011, 07:21 PM
My 260 does fine.
What kind of 560
Old June 22, 2011, 07:27 PM
Coffaholic's Avatar
What resolution do you play at? That is a pretty important bit of info for a recommendation.
I havent actually used fraps while playing since I got my 560Ti but at 1920x1200 I have no problems with most everything at max. Its not a min 60fps though it doesn't drop anywhere close enough to stutter.
| Q8400 @ 500x8 w/ Corsair H70 | EP45-UD3R rev1.1 bios F11 | 2x2gb Gskill F2-8000CL5-2GBPQ @ 500Mhz | EVGA 560 Ti @ 960/1920/2150 | 64gb Patriot Torqx M28 |
| PC P&C 750w Silencer | Soyo 24" DYLM24D6 | Silverstone Fortress FT02B-W with Air Penetrator fans |
Steam \ BFBC2 ID - Coffaholic | RIFT - Coffaholic \ Perspice Shard
Old June 22, 2011, 07:28 PM
or a 6950.
or a highly clocked 6850/gtx460 :)
Old June 22, 2011, 07:36 PM
Coffaholic's Avatar
Oh yeah, what are your current system specs?
The more info we have the better. We could be giving bad advice suggesting a card that your PSU cant handle for example. You should head to your UserCP and fill out your specs so all the info is available.
Old June 22, 2011, 07:49 PM
Arinoth's Avatar
According to his system specs, he's gaming on a 42" LCD 1080p TV so his resolution is most likely going to be 1920 x 1080, although he should probably more look towards a card that'll have a harder time maxing BF3 then BC2.
Here I am: here I remain
Old June 22, 2011, 08:02 PM
Coffaholic's Avatar
Yea, its there now.
I just played a bit, jumped on a few different maps. Close quarters with lots of stuff going on I never saw it dip below ~70fps. This is at 1920x1200 with everything on high, 2xMSAA, 4xAF, vsync and HBAO disabled. The numbers I remembered must have been with my 5850.
Old June 22, 2011, 08:11 PM
Originally Posted by Coffaholic View Post
Yea, its there now.
on battlefield bad company 2 with 5850 never dropped below 70 fps?
Old June 22, 2011, 08:26 PM
Coffaholic's Avatar
It was 70fps with the rig in my signature. I played for a while after my first post in this thread. It was lower with the 5850.
