Old June 22, 2011, 11:14 AM
zeus3dfx
Guest
Posts: n/a
Default Upgrade from a 8800GTX?
Hi all, I'm in a bit of a confused state regarding my rig lately. My 8800GTX OC can play most of my
games at 1920x1080 but is having problems pushing high quality on some of the newer titles like metro 2033.
Naturally, I'm thinking of upgrading. What should I get? Keep in mind I like nVidia more nowadays, I don't really want to spend more than $200 and I'm still on the P35 chipset with q6600.
Old June 22, 2011, 11:16 AM
think first of a cpu mobo ram overhaul , then worry about graphics.
2500k right now,well see when dozer hits about recommending their 4 core(times two little dwarfs)
instead :)
Old June 22, 2011, 11:23 AM
zeus3dfx
Guest
Posts: n/a
instead :)
It's going to be hard to let go of my trusty old Q6600. We've been through too many battles together
On a more serious note, will a change to sandy bridge bring that much more of a performance increase?
Old June 22, 2011, 11:24 AM
cpu and chipset will suffice.. But you've got a really aging card from ages ago. I really suggest looking into upgrading to at least a 560 Ti or 560
And yes .. switch to SB would warranty a pretty substantial increase in overall performance.
Old June 22, 2011, 12:06 PM
well, its no fun having a decent video card with a slower older system :)
even if you just went with the cpu mobo ram upgrade you will see better performance , with the same old card.
if you want to stay nvidia, as per above but get the ti version of the 560. the non ti is like a higher clocked 460..:)
Old June 22, 2011, 12:18 PM
Its better to upgrade the GPU first and if your not happy then upgrade the rest. Why spend a bunch of money into something that may not necessarily be needed?
And there is nothing wrong with the 560s. Just cause its an overclocked 460 you still get benefits of a decent fast card with lower power requirements and a new GPU.
Old June 22, 2011, 12:47 PM
yeah but he can find 460's for a chunk less :)
Old June 22, 2011, 12:50 PM
And have an older card that dumps more heat and uses more juice.. right!
Old June 22, 2011, 12:55 PM
Eldonko's Avatar
Hardware Canucks Reviewer
I would go with a 560 ti and if you still feel the need to upgrade then go to SB
Old June 22, 2011, 01:24 PM
looks like another vote for the ti 560 ;)
VGA upgrade from GTX 260 first, or CPU+mobo upgrade first? panzerfan Video Cards 9 April 6, 2010 08:25 PM
[WTB] looking for 8800GTX kuziwk Buy/Sell & Trade 0 January 18, 2010 04:03 PM
8800gtx miggs78 Off Topic 9 January 15, 2010 07:26 AM
[WTB] 8800GTX Chos3n Buy/Sell & Trade 7 April 10, 2009 04:00 PM
[WTT] trading my 8800gtx shayan288 Buy/Sell & Trade 0 January 8, 2009 03:27 PM
