  #21 (permalink)
Old June 24, 2011, 09:04 AM
zeus3dfx
Guest
Posts: n/a
Originally Posted by Phill View Post
At 1080P I would think that just upgrading to a 560Ti will still be about the right move... then run the system for another year and do a whole system upgrade. If your q6600 is not oc'd I would highly suggest that you do!
FWIW I use a 2500K at 5.0Ghz with 570 SLi and my wife has a Q6600 at 3.5Ghz with a 580. The q6600 does hold back some but it is still very useable at 1080P+.
The q6600 has been great for me. Probably my best purchase of a CPU ever, even better than my tualatins and athlon mp's back in the day.
Thanks for the info everyone, I have decided to keep my main components as is and just upgrade my video card for now. I will be going with just a regular GeForce GTX 460 which I can find for a good price and won't have to break the bank. Can anyone recommend a good vendor for it? EVGA, Asus, MSI?
  #22 (permalink)
Old June 24, 2011, 09:16 AM
The cost difference between the 460 and 560 is so minimal now its not worth buying a 460 unless you get it used.
  #23 (permalink)
Old June 24, 2011, 09:25 AM
zeus3dfx
Guest
Posts: n/a
The 560 has better power consumption and heat output right? I might go with it then. The Ti version is out of the picture since it is over my budget.
  #24 (permalink)
Old June 24, 2011, 09:48 AM
Correct. Whether you go for the 560 or 560 Ti you'll have a good card that will be miles better than your 8800GTX
  #25 (permalink)
Old June 24, 2011, 10:03 AM
Dzzope's Avatar
As the card is kinda a stop-gap and considering that a 460 can pretty much match a 560, I'd go second-hand.. save you a bunch of bucks.,.. there are many to be had out there.
And if you consider the 5770, it's about the same as a 460, they are cheaper again.
If your going new then a 560 would be good.. have you looked at the red camp options in your budget? I'm not 100% but I think at your budget they are quite strong.
  #26 (permalink)
Old June 24, 2011, 03:17 PM
A 5770 is quite a bit slower than even a 460 768.
AnandTech - Bench - GPU11
Red camp
6850
NCIX.com - Buy Sapphire Radeon HD 6850 775MHZ 1GB 4.0GHZ GDDR5 2XDVI DisplayPort HDMI PCI-E Video Card - SAPPHIRE - 11180-00-20R - in Canada $159.98 no mail in rebate
5770
NCIX.com - Buy Powercolor Radeon HD 5770 850MHZ 1GB 4.8GHZ GDDR5 DVI HDMI VGA DIRECTX11 PCI-E Video Card - PowerColor - AX5770 1GBD5-H - in Canada $89.99 after $20 mir
Green Camp
560
NCIX.com - Buy Zotac GeForce GTX 560 820MHZ 1GB 4GHZ GDDR5 2XDVI Mini HDMI PCI-E Video Card - Zotac - ZT-50701-10M - in Canada $169.99 after mail in rebate
Really though like Dzzope said if you are going to a 5770, 6850 or 460 go second hand. going new go 560
  #27 (permalink)
Old June 26, 2011, 05:31 PM
Dzzope's Avatar
Yea... dunno what I was thinking there... but it's still a decent card (as a stop gap) and it's hella cheap second hand..
  #28 (permalink)
Old June 27, 2011, 05:25 AM
If you are thinking of overhauling your system pick up a used HD5870 for around $180-$200. Honestly 5870's are just kickass cards, they can handle most things but they don't do dx11, but then again neither do any of the other cards other than a GTX 560 which isn't worht the money.
I have been informed that the 5870 was the first DX11 GPU... Now there is no reason not to pick up a used one. I thought all of the 5000 series were DX10 but apparently I was wrong.
  #29 (permalink)
Old June 27, 2011, 05:28 AM
Galcobar's Avatar
The 5000-series from AMD was the first to run DX11.
VGA upgrade from GTX 260 first, or CPU+mobo upgrade first? panzerfan Video Cards 9 April 6, 2010 08:25 PM
[WTB] looking for 8800GTX kuziwk Buy/Sell & Trade 0 January 18, 2010 04:03 PM
8800gtx miggs78 Off Topic 9 January 15, 2010 07:26 AM
[WTB] 8800GTX Chos3n Buy/Sell & Trade 7 April 10, 2009 04:00 PM
[WTT] trading my 8800gtx shayan288 Buy/Sell & Trade 0 January 8, 2009 03:27 PM
