Old June 12, 2011, 08:57 PM
Default gtx 2 way sli, no sli option
I have 2 gtx 480's in my asus p8p67 m pro board and there is no sli ption in the nvidia control panel. Ive tried new drivers, old drivers, fresh instakll of windows, uninstalling realtek lan and audio, switching the cards around, cards in different slots (x16/x4) and (x8/x8) They both show up but no sli option, just physx. It also says to put the 2nd gtx in a high performance pci e slot, it already is though. Can someone help me?
Old June 12, 2011, 09:03 PM
ASUSTeK Computer Inc. - Motherboards- ASUS P8P67-M PRO
- CrossFireX Support
- SLI Support
hmmm both should be cool.
do you have the connector on? try it the other way around
one card in,boot up. let the drivers go on. shut down. second card in. at first no connector,then connector?
also,might sound dumb, but try the sli trick? i did that when the control panel
got messed up and didnt care to find out why/reinstall :)
ps welcome around!
Old June 12, 2011, 10:55 PM
Caldezar's Avatar
I wonder if the P67 is suffering from the same driver issue the 990FX is? Try downloading the Quadro beta drivers here and giving that a whirl. I'd be interested to see if this is the case, as it would certainly expand nVidia'a blunder.
Old June 13, 2011, 09:39 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Should work, do you have your SLI bridge installed?
Old June 13, 2011, 11:05 AM
I will try those drivers. What is the sli trick? Yes sli bridge was on. My old 560 ti's never had this problem. Will get back with the results. It wont let me install the quadro drivers. Says they are not compatible with my card.
Old June 13, 2011, 11:21 AM
Sli For The Non Believer [Guide How To Eenable SLI On Non SLI Cert Mobo]
Old June 13, 2011, 11:50 AM
I will try that right now. Talked to nvidia about my problem, they were quite useless.
Old June 13, 2011, 12:04 PM
back up your data before
usually on fresh installs of windows there are no problemos.
not that i haven't tried it on older installs ,with success of course :)
Old June 13, 2011, 12:05 PM
are you sure it's a p8p67m pro ? the p8p67m suport only xfire
Old June 13, 2011, 12:47 PM
Did fresh install of windows, 4 times. Sli patch didnt work. Yes it is a asus p8p67 m pro, I had 2 gtx 560 ti's in sli before.
Sli For The Non Believer [Guide How To Eenable SLI On Non SLI Cert Mobo] _dangtx_ Video Cards 13 January 25, 2011 04:25 PM
gtx 460 1GB Sli & E6300@3GHz with ASUS P5N32-E SLI ro9ue Video Cards 0 September 19, 2010 10:30 AM
GTX 480: To SLI Or Not To SLI, That Is The Question? TheGregster76 Video Cards 22 June 15, 2010 05:47 PM
GTX 295 sli vs GTX 275 tri-sli phil3_66666 Video Cards 12 April 29, 2009 11:03 PM
No SLI option tzetsin Troubleshooting 20 August 24, 2008 06:38 PM
