Old June 13, 2011, 12:51 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Could be a bad board. I had a MSI board once that would not run SLI. 2nd slot wasnt working properly so I RMAed. Maybe try each slot individually?
Old June 13, 2011, 01:00 PM
The 2nd card shows up in the nvidia control panel. Shows only physx, no sli option.
Old June 13, 2011, 01:05 PM
Eldonko's Avatar
Mine was the same. It was there but there was no way in hell to enable SLI. If you did a clean windows install and it still doesnt work there has to be a problem with the board or your SLI bridge.
Old June 13, 2011, 01:40 PM
Originally Posted by bshan67 View Post
Did fresh install of windows, 4 times. Sli patch didnt work. Yes it is a asus p8p67 m pro, I had 2 gtx 560 ti's in sli before.
so SLI was working on that board, is it posible that 1 SLI connector on the card himself don't work
Old June 13, 2011, 02:47 PM
wait, what happened with the sli trick?
do go in detail...i got lots of experience in that field. ive done dozens
of boards with success.
Old June 13, 2011, 03:02 PM
since it's gtx 480, chance they are new or have been manufacture a long time ago take an staedtler eraser and clean ( rub) the SLI contact on the GPU
Old June 13, 2011, 08:13 PM
Nothing happened with the sli trick. I installed it, rebooted, stated in sli windows 7 option and I had no sli option. Is it because I have a p67 board? Also I read that you dont even need a sli bridge for sli to show up in the control panel.
Old June 13, 2011, 08:19 PM
then there is something phisically messed up somewhere lol. as per above.
or youre very unlucky and its still software
but the sli trick kinda confirms me fears
  #19 (permalink)
Old June 14, 2011, 01:48 AM
I was reading that the sli patch doesnt work on p67 boards. Either way what do you suggest I do now?
  #20 (permalink)
Old June 14, 2011, 02:30 AM
Well guys thanks for all your help but I have had enough of this and broke down and bought a new board. I bought this one (here) Tell me what you think.
Sli For The Non Believer [Guide How To Eenable SLI On Non SLI Cert Mobo] _dangtx_ Video Cards 13 January 25, 2011 05:25 PM
gtx 460 1GB Sli & E6300@3GHz with ASUS P5N32-E SLI ro9ue Video Cards 0 September 19, 2010 10:30 AM
GTX 480: To SLI Or Not To SLI, That Is The Question? TheGregster76 Video Cards 22 June 15, 2010 05:47 PM
GTX 295 sli vs GTX 275 tri-sli phil3_66666 Video Cards 12 April 29, 2009 11:03 PM
No SLI option tzetsin Troubleshooting 20 August 24, 2008 06:38 PM
