Hi people,
I'm building a new gaming pc and i need your help with the decision of wich VGA card i should buy.
Here (in Chile) the MSI 560 Hawk Twin Frozr III (950 MHz) and the Gigabyte 560 SOC (950 MHz) cost the same, but the 6950 Twin Frozr III cost like 40 bucks more. I've read reviews of the 3 cards, and all of them are really good (in performace and temps), so i really don't know which one to buy.
By the way, the max resolution i'm gonna use is 1920x1080.
Which one do you recommend?
Thanks for your help
PD: I'm building an i5-2500k Sandy Brigde system with a Asus P8P67 Pro mobo and 4 GB ram if that helps in some way.
