(skip this paragraph if you like, not really important)
So, I solved the graphics card issue I had before, which is very sketchy.
Was basically putting my case on its back and un screwing it from the case. (the connector seemed to have semi failed) I tried erasing the gold connectors, but it still did not work. So now I have a semi fixed gpu pending RMA once I decide on what to do next.
So i was thinking of getting this card:
NCIX.com - Canada's Premier Computer Store - Online PC Discount Store, Buy Computer Accessories
(asus 5870P MATRIX
its the better version of mine I believe. which is a EAH 5870. both cards are made by asus and my mobo has 16x, 16x configuration.
I`m curious if this will be stable and if its a good match as I cant find the EAH 5870 anywhere...
Thanks for the help in advance.
