Old June 4, 2011, 05:49 AM
matsta31's Avatar
yeah I had the same issue....but my lcd had DVI I needed to go out and buy a DVI cable.
And for 3 LCD on one 6870, it is really not that bad on FPS. Sure you have to play on medium settings but it does good.
Sold hardware again.....
Currently using WHS hardware....
Old June 4, 2011, 09:25 AM
ya you can pick up non-active display port to dvi converters
also the higher end cards have the same limitations
1 monitor has to be on the display port
the other 2 can be on any of the other connections
Old June 4, 2011, 05:50 PM
matsta31's Avatar
non-active x 2 = fail
Old June 5, 2011, 09:32 AM
you sir do not know what you talk about
there are SINGLE LINK display adapter to DVI
specifically made for eyefinity
my best friend has one, he had the same problem
Newegg.ca - eyefinity adapter
he had gotten other display adapter to dvi and it did not work
once i showed him this. all his problems went away
Old June 5, 2011, 10:01 AM
just don't go over 1900 resolution
then you need active dual link
Old June 5, 2011, 10:10 AM
Who doesn't know what they are talking about?
If you know how to connect 3 VGA monitors to a 6870, please tell me. I'll pass it on to Diamond MM.
Are you saying that I should connect the monitors as follows:
1) VGA->DVI adapter>DVI-I port (done)
2) VGA->displayport adapter->mDP adapter->mDP (done and working via a $12 ebay adapter)
3) ???????????????????
Old June 16, 2011, 05:45 PM
Default 3 x VGA + adapters DOES work
Long story short, I now have a Powercolor 6870 running my 3 VGA monitors in eyefinity - using the DVI-I port and both mini-DPs. AND using $14 mini-DP ->VGA adapters at that.
[FS] Asus 6870 and Saphire 6870 Graphic Cards Arinoth Buy/Sell & Trade 1 January 26, 2011 06:41 PM
Multi-function printer saltyvinegar Peripherals 3 June 23, 2009 02:05 PM
Ignore function? Squeetard Suggestions & Feedback 30 January 15, 2009 03:07 PM
Invalid MS-DOS function tzetsin Troubleshooting 7 December 24, 2008 04:06 PM
Search function Eldonko Suggestions & Feedback 3 May 25, 2008 07:09 PM
