  #21 (permalink)
Old June 2, 2011, 02:47 PM
Originally Posted by Eldonko View Post
That's because they were dvi-i, now you only have 1 dvi-i so you need hdmi to vga, like so HDMI to VGA HD15 (Male) Cable: Amazon.ca: Electronics
Really gets my back up when someone else says that nothing has changed in all caps.
  #22 (permalink)
Old June 2, 2011, 04:29 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Direct from AMD:
I really can't say any more than that....
The display connectivity hasn't changed from the HD 5000-series as many cards are using the same traces, etc as the HD 5000 series. RAMDACs are the same as well.
Plus I just tried running a 2560 x 1600 display off the #2 (supposedly) DVI-I connector on a HD 6970....it worked.
All I am saying is that the layout may be different but if you are using the reference design from each generation, nothing should have changed. Non-reference cards though....your guess is as good as mine....
  #23 (permalink)
Old June 2, 2011, 05:36 PM
DVI now comes in four flavours though.
-D single link
-I " "
-D dual "
-I " "
why does -D even exist? Other than to cause headaches?
  #24 (permalink)
Old June 2, 2011, 06:18 PM
My guess would be that the manufacturer doesn't have to worry about running traces for an analog connection with DVI-D making it a little easier and maybe a little cheaper to design the pcb. Unfortunately like it or not analog(vga) is slowly being phased out, especially on mid to highend cards.
Single Loop or Dual Loop? Pump enough for single? MattC Water Cooling 5 May 31, 2011 07:19 PM
Dual-Link crossfire hookup for 2560x1600 Dogger1 Display Units 2 November 21, 2010 07:38 AM
Forcing Single-link DVI output xilocient Video Cards 1 May 5, 2010 05:26 AM
Change Dual to Single Boot? lechumbl O/S's, Drivers & General Software 9 February 23, 2010 08:20 PM
Need help with my dual rad in a single loop jusdrink Water Cooling 33 June 20, 2009 03:43 AM
