Old May 31, 2011, 08:09 AM
Default 8800GT 6pin plug
Hello, after i bought 8800GT graphics card, i saw that it needs a 6pin power plug, which i dont have. So i went to electronics shop, and bought Power Pci-express 2x 4pin to 6pin cable, and having problems, couse i dont know where to plug those 2x 4pin. 6 pin goes to video card, but where to plug those 2x 4pin?
Old May 31, 2011, 08:14 AM
Into the ends that look like they would plug into :P
I don't trust those adapters to be honest and if your power supply lacks a 6 pin perhaps look at getting a inexpensive psu that does.
SugarJ's Avatar
The 4 pins plug into any open plugs from your power supply. But be forewarned that Nvidia says you need at least a 400w power supply to run a 8800GT.
Edit: 'd
Old May 31, 2011, 08:23 AM
ye i have 420w, but tbt from psu only goes 4pin, that can be plugged into, same as cable http://www.xscable.com/prodimages/CC2125Y_LR.jpg like those on the left, i need those on the right
Old May 31, 2011, 08:25 AM
SugarJ's Avatar
It sounds like you have the wrong adapter then.
You need one that looks like this: NCIX.com - Buy nGear 4 Pin Male Molex Power to 6 Pin PCI-E Power Adapter Cable - nGear Technologies Inc. - NG-4PMM-6PVF - in Canada.
Old May 31, 2011, 08:26 AM
if you look at the plug ins to your hard-drive and cd-rom drive
those should look like what you plug into, unless they are sata drives, then they are different
but like they said look for any plugs coming out of your PSU that look like the ends to connect to
Old May 31, 2011, 08:31 AM
yeh i need to plug those 4pins into like cd rom slot
Old May 31, 2011, 08:32 AM
refresh my memory on the brand and model of your psu before it blows? (hopefully not :))
Old May 31, 2011, 08:50 AM
Sinan
let it blow, searching parts for a new pc ;p
Old May 31, 2011, 09:00 AM
That adapter is allow 1 molex connector to be turned into 2
[FS] Last chance to buy (sensitivity mode) custom-made, uni-sleeved 6pin PCIe cable :) Artel Buy/Sell & Trade 12 May 26, 2010 10:00 AM
[WTB] 775 cpu, ddr2 ram/bare basics multi-GPU system/ 6pin and 8pin PCIe cables (modular) Artel Buy/Sell & Trade 13 May 20, 2010 04:31 AM
Confused over 6pin and 8pin, and power capacity of pcie plugs 0o0 Power Supplies 7 February 1, 2010 03:58 AM
[WTB] Seasonic 8pin & 6Pin PCI-E Overclocker~4.1 Buy/Sell & Trade 3 December 10, 2009 08:08 PM
[WTB] 6pin male to 6pin male power cable for videocard kyle_L Buy/Sell & Trade 1 September 17, 2009 02:04 PM
