Old May 29, 2011, 09:54 PM
Default VGA for old board
i have an old P5GD1 775, does have 1xPCI express slot slot, im looking for a graphic cards that will fit my board, i know there are some low end cheap card to fit, but im looking for something with higher performance, please give me some idea to which card to use.
Old May 29, 2011, 10:50 PM
you won't find anything powerful for a 1x pci-e
because the bandwidth is too limited to provide for anything too powerful
that motherboard has an AGP slot though
the most powerful card you can get for it as AGP (done from highest to lowest)
is a ATI 4670, next is ati 3850, ati 4650, nvidia 7950 gt, ati x1900 xt
well that put me down memory lane...
Old May 29, 2011, 11:13 PM
Mook06's Avatar
ASUSTeK Computer Inc. - Motherboards- ASUS P5GD1
this one has a x16 slot, is this your board?
Old May 29, 2011, 11:49 PM
NCIX.com - Buy ASUS P5GD1 ATX LGA775 915P DDR PCI-E16 2PCI-E 3PCI SATA RAID Sound GBLAN Motherboard - ASUS - P5GD1-UAY0 - in Canada
that it?
you could throw in an 8800gt or the like,probable be bottlenecked,psu an cpu alike
ps welcome aboard arr!
Old May 30, 2011, 08:21 AM
@mook, yes that's the board
i understand some bottle neck issue does the HD3450 fit my board? maybe i should be looking for something around 512MB.
Old May 30, 2011, 03:35 PM
wait thought it had agp slot
anyways if thats the case...you can use a standard PCI-e video card
theres nothing stopping you from using whatever you want in there
Old May 30, 2011, 03:37 PM
could we know what the system looks like in full? :)
power supply too.
Old May 30, 2011, 05:11 PM
Mook06's Avatar
id get a cheap nvidia card that supports cuda, the 8800gt example is good (i still use one, great for video and still runs any game)
as long as your psu can handle it ( 20amps @ 12v ) ish
Old May 30, 2011, 05:33 PM
We'll need more information to know if a GPU upgrade is what you need:
What do you need the higher performance for?
If you game, what is your resolution?
What OS are you running?
What is the make and model for the following: CPU, RAM (+ amount of RAM), primary hard drive, power supply, case, current video card
A Radeon 3450 is barely better than modern integrated graphics for gaming, but if all you need is blu-ray playback it should be fine.
Old May 30, 2011, 08:36 PM
P5GD1 socket 775LGA
p4 530
2G rams ddr but will upgrade to 4G if necessary, anyway window max out at 3G i think
160G HD
450W power supply
current graphic Nvidia Geforce PCX 530 128M
running XP, did try to upgrade to window 7, but there are no graphic driver.
basically is for gaming, not any hardcore game just fairly mild game
can anybody please tell me if these card will fit my board, i just want to make sure if it does fit, these are my choice or any recommendation is appreciated.
PALIT 210 512MB DDR2
GIGABYTE GT210 1GB GDDR3 64 BIT 590/1600 TURBOCACHE
Spark GF 210 1GB DDR3 LP 64-bit DVI HDMI PCIe 2.0, 16 CUDA
GIGABYTE 8400gs 512MB D2
HIS ATI Radeon HD 5450 1GB DDR3 64-bit DVI HDMI PCIe2.0
[WTB] VGA Box Behemoth- Buy/Sell & Trade 0 December 18, 2010 04:01 PM
More VGA BS Dr_BenD_over Gaming 8 November 18, 2010 10:10 PM
[WTB] (GVR) BFBC2 4 Pack, VGA Cable, & DVI-VGA Adapter jcmaz Buy/Sell & Trade 10 April 10, 2010 07:53 PM
Spike VGA's Dr_BenD_over Gaming 6 November 19, 2009 08:28 AM
[WTB] Need VGA cable b1lk1 Buy/Sell & Trade 4 September 23, 2009 09:50 AM
