-   -   6970 temp question (http://www.hardwarecanucks.com/forum/video-cards/43492-6970-temp-question.html)
ultraman7k May 22, 2011 05:20 PM
6970 temp question
hey guys,
picked up a Sapphire 6970 2gb reference the other day and did some digging for the temps.
from what i can tell, idle should be ~35 degrees? Mine is currently running around 50 degrees with the fan automatically set at about 26%. I haven't overclocked this or anything, any suggestions on what to do, or is this normal?
Thanks.
Coach May 22, 2011 09:54 PM
you running more than one display? If so there you go
_dangtx_ May 22, 2011 10:06 PM
depending on some factors, 50c with 26% is not that bad :)
more importantly,hows load temps? 3dmark/furmark?
ultraman7k May 23, 2011 12:15 AM
ah yes. 3 displays. that would do it.
what an oversight on my part haha. thanks.
Coach May 23, 2011 10:49 AM
Ya your Card will run higher clocks with more than one display even idling at the desktop.
