<~----> How's the gtx 560 ti - Hardware Canucks
Old May 20, 2011, 08:49 AM
Default How's the gtx 560 ti
I am considering the gtx 560 ti for my new build
my budget is <300 for graphics card
i was wondering if it can max out all games (also upcoming games like DiRT 3) in 1440x900 res
also can anyone tell me what the difference is b/w gtx 560 ti and gtx 560
and how's gtx 470 compared to it
Old May 20, 2011, 09:08 AM
Can't go too much in details, but 1440 x 900 isn't a very demanding resolution by today's standards. DiRT 3 will be able to be maxed out with that card provided your CPU isn't bottlenecking you(and since its a new build, I doubt it would....
I would recommend most lilely getting a new monitor, or planning to get one and consider the new resolution in your purchase.
Perhaps something like a 6950 would be a better purchase considering your budget, preferably 2gb if you got for a fairly big resolution monitor, but as it is now, 1gb is all you need (possibly that's all u need unless u go above 1080p)
Old May 20, 2011, 09:15 AM
at that res, i think a 6850/gtx460 will do allright,no need to spend a lot of cash.
Old May 20, 2011, 09:29 AM
francisw19's Avatar
The GTX560Ti is a good card for the money. Agreed with the guys above...at your res, it will have no problem running your games. I run a pair in SLI with a single 1920x1200 display and they've treated me well.
Also, to answer your question about 560 vs. 560Ti...AFAIK, the 560Ti just has more shaders. Either card would be fine for your current setup.
Old May 20, 2011, 10:17 AM
thanks
i may upgrade my monitor
not sure
but which one's better gtx 560 ti or the gtx 470 ?
Old May 20, 2011, 10:21 AM
Originally Posted by Jim Clifford View Post
thanks
not sure
5 > 4
Old May 20, 2011, 10:22 AM
Keywork's Avatar
560 Ti for sure. Runs faster, cooler, and uses less power! WIN, WIN, WIN lol.
Old May 20, 2011, 10:24 AM
Arinoth's Avatar
The 560 Ti is better then the 470 with regards to both performance and temperatures
Old May 20, 2011, 10:30 AM
thanks
Old May 20, 2011, 10:33 AM
check this out : AMD Radeon HD 6950 1 GB Review - Page 1/26 | techPowerUp
GTX 560 Ti problems. adamdavidson Troubleshooting 8 April 4, 2011 11:21 AM
GTX 560 Ti OC cooler mchutch Video Cards 6 February 22, 2011 10:58 AM
Gtx 560 Ti vs Gtx 570 Hexofire Video Cards 7 February 21, 2011 11:07 AM
Rumor of GTX 570 and GTX 560 on its way vohiep84 Rumor Mill 15 November 20, 2010 07:43 AM
