Old May 15, 2011, 06:11 PM
Question is this V2 design?
Hi all,
First picture I've got from coolingconfigurator.com site. Second is my own HIS 6970 PCB design.
The only difference that I can see are the caps along the "square-shaped" components.
Secondly, two caps near the power connectors, and
Thirdly, the caps in the lower-right corner.
Is my card's PCB an V2 design? I'm trying to get the right waterblock for it.
Thank you.
Old May 15, 2011, 06:37 PM
werty316's Avatar
Unless I am mistaken, the top pic is a reference design.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old May 15, 2011, 06:41 PM
correct. reference design had the 'sawed off' plastic corner :)
look up the high rez piccies on tpu.
Old May 15, 2011, 06:49 PM
werty316's Avatar
Found it here: HIS Radeon HD 6970 2 GB Review - Page 4/33 | techPowerUp
Old May 15, 2011, 07:21 PM
I know the top one is the reference design...The second pic is what I'm interested in...is it the V2 design? I need to get the right waterblock for it.
The coolingconfigurator.com is no help.
Old May 15, 2011, 07:30 PM
dont think so, but you never know till you try
those components are probably not the same height either
Old May 16, 2011, 06:42 AM
Dang thing is...None of the watercooling store is here in Edmonton.
I don't want to waste money just to buy a block, and find out didn't work later, "poof!" money well spent
Old May 16, 2011, 07:12 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
If you are looking for a full cover block, it won't fit due to the location of the capacitors. There is no real "V2" design as every board partner is free to build their own designs as long as they stay within the minimum specification limits AMD sets out in their design documents.
Old May 16, 2011, 09:00 AM
although daz could help you out perhaps? pcb numbering helps,specially if youve got the same card on the table there
Old May 16, 2011, 12:29 PM
Emailed Daz with pic and he said no clue.
After I've searched all over the 'Net finally found something...Mine is the top one.
What do you guys think? From Coolingconfigurator.com, the V2 from Powercolor...all the caps matched with mine.
If I were to design a motherboard… Epimetheus CPU's and Motherboards 10 May 27, 2011 05:17 AM
My loop design Patlabor Water Cooling 16 March 20, 2011 11:58 AM
need advice on design Beermaster Water Cooling 7 June 28, 2009 07:17 PM
Pump design. BrainEater Off Topic 3 June 20, 2008 05:47 AM
Help design new rig. BALISTX CPU's and Motherboards 30 December 9, 2007 01:12 PM
