Originally Posted by Diamondtech No they do not locked or unlocked they will not match up. In crossfire the other card will only be uses as a reserve it would not use the the full GPU and ram. Crossfire does not double the cards power. 1 GPU will be used for rendering the other will display the video. |
Completely false, both GPU's will render graphics equivalently assuming their the same power. So say you have two 6950's you can expect 99%/99% usage in a game properly optimised with VSNYC disabled. If you have a 6970/6950 combo you can expect 90%/99% usage in a well optimised game (the 6970 will perform at 6950 spec unless u OC the 6970).
That said I would advise against crossfire, frankly it sucks, drivers and fixes are always late and not completely functional. ATM I still find I'm better off playing Witcher 2 and Crysis 2 with just one of my 5850's instead of both :( Only things it performs well in are benchmark games and actual benchmarks.
