  #21 (permalink)
Old May 11, 2011, 08:11 AM
rapmaster's Avatar
Originally Posted by geeti View Post
If I don;t want to flash the 4950 with full 4970 bios, instead unlock the locked shaders and manually up the clocks, is it possible with all 4950's 2 gig? I dont want the reference cards because of the shity and loud fan it comes with.
Only reference cards can be unlock.
Quando omni flunkus moritati
  #22 (permalink)
Old May 12, 2011, 08:37 AM
Originally Posted by lKashl View Post
Pretty unconventional suggestion but may i advise looking towards a 58 series card? Given that a 5870 lags behind a 6950 by only like 1% in performance but is often 33% cheaper I would say its a better solution. Also you might be able to pick up 2x5870's for a relatively similar price to one of the high tier 6950's, so you really cant go wrong, just check out Toms Hardware chart if you need to be convinced.
This generation of video cards was hardly a performance leap over the last, even eVGA are releasing a 2xGTX460 card (if i remember correctly) that squishes or comes close to a GTX580. I wouldN'T recommend purchasing a last gen nvidia card though since Fermi's first gen was notoriously hot and power consuming compared to the GTX5's ;)
Im going to look into it, thanks for the info.
Sandy Bridge GPU vs. 1156 GPU vs. Mobo Integrated GPU vs. "Straight Up" GPU ImmaPC HTPC Systems & Software 5 March 16, 2011 04:41 AM
[WTT] $300 CDN emt for $300 Paypal credits. DONE!!! Thank You!!!!!!!!!! Mena Buy/Sell & Trade 3 August 12, 2010 08:15 PM
Cooling GPU. Antec 300 case TMan Air Cooling 1 September 18, 2009 03:07 PM
Dual GPU Folding on one GPU (FahCore_14 only) geokilla HardwareCanucks [email protected] Team 2 August 8, 2009 05:35 PM
50 Million! Top 20 PPD! Top 100 overall! zlojack HardwareCanucks [email protected] Team 46 May 4, 2009 12:42 PM
