Hi guys,
Well I decided to pick up three 5850s (Sapphire 5850 Extreme 1GB) primarily for folding and I am having a pretty big problem with heat at full load.
As the cards are not reference (they are the new, cheap $150 5850s), the fans don't exhaust the heat out of the system. At idle; my temps are as follows:
Top: 45C @ 39% Fan
Middle: 52C @ 50% Fan
Bottom (right above power supply which is acting as an exhaust): 42C @ 39% Fan speed
At load (100%):
Top: 81C @ 84% Fan speed
Middle: 88C @ 99% fan speed (and rising)
Bottom: 72C @ 64% fan speed
How it looks:
My case is an Antec 902 with an additional 120MM side intake case fan added (right above the GPUs). Every single fan is running at it's highest setting inside the case.
As I do not feel comfortable having my GPUs at 85-90C 24/7 with the fans at 80-100% power, what do you guys recommend I can do? Should I turn the side intake fan directly across from the GPUs into a exhaust? Should I add another 120MM fan in my hard drive bay?
I am also currently monitor the videocards through ATI overdrive (not MSI afterburner).
Thanks in advance.
