Old May 4, 2011, 03:19 PM
Default My new temps
Now I got my new case
Temp with old case MSI Kombustor furmark NO OC: 87C
Temp with HAF X OC to 930/1300: 80-82C
Is it good or bad??
Temps without OC are about 3-4 degrees lower
Old May 4, 2011, 03:20 PM
JD JD is offline
Seems about average. Video cards are design to run at 100C (or more for some cards).
Old May 4, 2011, 03:33 PM
SugarJ's Avatar
I'd be more concerned with max gaming temps than Furmark, myself. Furmark loads GPU's more that any game, so it's not realistic in my books.
And Nvidia chips start to thermal throttle when they reach 105 degrees. Speaking from experience. Your 80 degrees or so should be fine, and not shorten the life of the card.
Edit: Whoops, you've got an AMD. I'm not sure what max operating temps are for those, but you should be fine.
Are these temps ok? bvsbutthd101 CPU's and Motherboards 16 October 3, 2010 05:04 PM
Help with temps! ITaoI CPU's and Motherboards 2 August 16, 2009 05:20 PM
i7 temps gingerbee Overclocking, Tweaking and Benchmarking 1 March 9, 2009 09:02 AM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
temps Kassela Troubleshooting 7 March 13, 2008 02:46 PM
