  #111 (permalink)
Old April 13, 2008, 01:40 PM
sswilson's Avatar
What kind of idle temps are folks getting under the CCC temp monitor?
I'm seeing around 50c which seems kinda hot to me for idle, but maybe I'm just used to running Riva to bump the fan speeds up to 100%.
  #112 (permalink)
Old April 13, 2008, 02:34 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Are both cores @ 50? For me I was looking at about 48 / 52 for the two cores at idle.
  #113 (permalink)
Old April 13, 2008, 02:38 PM
sswilson's Avatar
There's only one temp shown in CCC, and I haven't loaded up riva tuner as it isn't my build and I'm not sure I want to go through the hassle to get RV up and running on it....... :)
Load temp running the freestone video stresser maxed out at 78c and I don't think it bumped the fan up at that temp (I'm guessing it's set at 80c???).
  #114 (permalink)
Old April 13, 2008, 04:09 PM
SKYMTL's Avatar
Can switch between "cards" in the CCC much like you would if you hadtwo cards in Crossfire. There should be a drop-down menu above the temperature readings.
  #115 (permalink)
Old April 13, 2008, 07:03 PM
sswilson's Avatar
Ok, thanks I check that out later. The computer's gone out the door for now, but I'll be getting it back next week for some more tweaking after the owner gets a chance to play with it for a while. (This build took wayyyyyy tooooo long!!!! :) ).
  #116 (permalink)
Old April 15, 2008, 04:46 PM
Mr. Cipher's Avatar
Sky, I love the humour you always include in your reviews - made it an enjoyable read. Seems that the 8800gtx may not be knocked off the top quite yet, but at least ATI is on its way.
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | BFG GTX 295 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Intel E1xxx & E2xxx OC Thread
  #117 (permalink)
Old April 16, 2008, 10:11 PM
Sky, any chance you can get ahold of Power Color's gddr4 version and do a comparison?
|- Welcome to the PowerColor World -|
  #118 (permalink)
Old April 16, 2008, 10:24 PM
sswilson's Avatar
Hrrmmmmmmm
I'm seeing 60c on one and 45c on the other at idle..... is that normal, or does it sound like the tim needs work?
  #119 (permalink)
Old April 16, 2008, 11:46 PM
MpG's Avatar
MpG MpG is offline
I'd vote yes, check the tim.
On a related note, I saw the post, and popped open Everest to see what kind of difference I was getting between my two cores... 45 degrees and 60 at idle. Ack! On water. Double ack!!!
Wasn't easy, but I managed to get the block off the card without opening the loop, and guess what I found? I'd forgotten to put TIM on the cores! Doh!
Anyway, temps are considerably lower now, and within 4 degrees of each other.
  #120 (permalink)
Old April 17, 2008, 05:29 AM
SKYMTL's Avatar
Unfortunately, no. At this time we have no contact with Powercolor.
Comment Thread for HIS Radeon HD3870 Review SKYMTL Video Cards 183 December 3, 2009 06:33 PM
Noctua NF-P12 Comment Thread SKYMTL Water Cooling 32 January 30, 2009 08:40 PM
Comment Thread for 500W PSU Roundup SKYMTL Power Supplies 11 November 25, 2007 12:51 PM
Comment thread for Thermalright HR-03 Rev.A Review 3oh6 Water Cooling 5 November 6, 2007 11:09 AM
Comment thread for MM U2-UFO worklog Babrbarossa Water Cooling 38 June 3, 2007 02:24 AM
