Old April 30, 2011, 05:09 AM
Default MSI Radeon HD 6950 Twin Frozr III
Is that card unlockable to a 6970?
If so, can you still overclock it and make it a super fast card?
If you do both of the above listed things, is there a card of the same value and faster than the card above when you oc it??
So is like a gtx 570 overclocked faster than a 6950 unlocked to 6970 and overclocked?
Edit: I just read that it is possible, but it is a gamble...
And the temps are very high...
Old April 30, 2011, 10:54 PM
GT7R's Avatar
If you use 1920x1200 or less, the 570 will be faster. At higher resolutions the 2GB buffer of the 69XX can come into play, but from what I've seen the 570 overclocks better than the high end radeons.
Old May 1, 2011, 12:59 AM
Yes it is unlockable but it is a game of chance. If you want to get the best chances stick with the 2GB version. The GTX 560 Ti is a direct competitor to the locked HD6950 and it costs about the same with the 1GB version. The GTX570 would be a good choice if you do not want to take the risk of unlocking the HD6950. The temps shouldn't be that high with the Twin Frozr II.
Old May 1, 2011, 10:07 AM
I doubt you'll have any problems keeping the temps within normal specs with the frozr cooler so long as you're willing to set a custom fan profile.
That said, according to reviews across the net, performance gains from unlocking the shaders on the 6950 are only about 2%, whereas the overclock to 6970 specs is reportedly what gives it the extra grunt. I can't confirm this personally, but my bro has an unlocked 6950 so if you want I might be able to get him to check it out.
MSI 6950 2gb Twin-Frozr 3...worth it? Socrates_Johnston Video Cards 15 April 7, 2011 09:11 PM
MSI N470GTX Twin Frozr II vs. Reference Radeon HD 6870 Draiko333 Video Cards 11 November 25, 2010 08:11 PM
[FS] MSI GTX 465 Twin Frozr II GE Iphikratous Buy/Sell & Trade 8 October 25, 2010 06:35 PM
MSI Twin Frozr or Cyclone? chanman Video Cards 7 September 3, 2010 10:26 PM
N275GTX MSI Twin Frozr - To WC or not to WC bkh2 Video Cards 0 January 6, 2010 11:31 AM
