Old April 29, 2011, 11:29 AM
Default Eyefinity resolution problem
Hey all.
I am running a triple screen racing rig with a Sapphire HD6950 2gb card. I have the display port monitor hooked up in the middle and the 2 DVI ports running the left and right one. The monitors are all exactly the same (24" Philips). I have always noticed that with the middle and the right monitor it the image was great, very crisp and clear. However, the one on the right was not as good, almost like it was set to a lower resolution even though it wasnt. I figured what the hell, it's off to the left anyway, I only really need to look forward and it looks good enough as it is.
Everything was great....until this past week. I fired everything up and the middle monitor had taken on the same characteristics as the left one. Things were more jagged, less crisp, text was a bit blurry looking. However, the right one still looks great. I have tried adjusting setting after setting and cannot get it back to "normal". Would anyone know at all why this could have happened?
Last night I downloaded the new 11.4 drivers but have not installed them yet. The resolution for the monitor group is 5760 x 1080 (each monitor is 1920 x 1080). If anyone has any help to offer I'd really appreciate it.
Thanks in advance.
RJ
Old April 29, 2011, 11:45 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Go into the Windows Display Manager and check the resolution there.
Did you set up Bezel Correction? If not, attempt to do so, create a new resolution and apply that resolution in the Display Manager.
eyefinity monitor flicker problem with new drivers ultraman7k Troubleshooting 2 January 22, 2011 08:00 AM
LGTV Resolution? davidbongman Display Units 8 July 7, 2010 04:05 PM
Resolution question Olorin Video Cards 7 December 25, 2009 07:49 PM
Resolution problem with Win7 xXxRithxXx O/S's, Drivers & General Software 6 May 5, 2009 07:24 PM
What Resolution Do You Game At? BALISTX Display Units 55 April 7, 2008 09:59 AM
