Old April 27, 2011, 12:09 PM
Slik's Avatar
Default Which video connecter to Monitor?
With two video cards there are 4 DVI connections to the monitor. Two on each card. Which one do you plug the monitor into? The top card or bottom card? The connection on the right or left of the card? Nvidia cards. Does it matter where you plug in the monitor?
EVGA DG 87 -i7 5930k @ 4.4ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 2400mhz- EVGA x 2 1080 Ti Black SLI - Soundblaster X7 Sound Card- LG 34" Monitor-ATH AG1X Headphones-Butt Kicker Gamer-TrackIR 5
Old April 27, 2011, 01:27 PM
Lpfan4ever's Avatar
Doesn't matter to my knowledge. I always do top card though myself, either side.
Originally Posted by encorp
Code:
<firebane> slightly used
SugarJ's Avatar
IIRC, you plug into the card in your 1st PCI-E slot (closest to the i/o shield). It depends on the card which is the primary display connection. You'll probably just have to try them.
Old April 27, 2011, 04:14 PM
Slik's Avatar
Thanks. I will move it to the one nearest the MB.
Old April 27, 2011, 05:19 PM
ZZLEE's Avatar
make sure the cable is duel link cable/ fore the 30 " monitor.
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old April 28, 2011, 06:51 AM
Slik's Avatar
Thanks guys, I do have a dual link cable. I never really had a problem with the inputs,I just wondered why there are two inputs on each card and which one to use. There must have been a reason to give a choice etc. Thanks again.
temp monitor for dual video cards CTA Video Cards 16 March 9, 2011 01:19 PM
Will video card kill a monitor? Slik Video Cards 15 February 22, 2011 08:19 AM
Samsung monitor video input problem technix Display Units 1 March 15, 2010 08:21 PM
Monitor, 1080p and video montage CactusJoe Troubleshooting 17 October 16, 2009 03:34 PM
Need Help!! S/PDIF Connecter TuX Audio 1 January 23, 2009 06:19 AM
