Originally Posted by dma0991 Furmark load is a little bit unrealistic as it will stress your GPU more than what you can expect from playing normal games. You could probably start by improving your case air flow by doing cable management or add more fans. Try testing this out with your side panel removed and run Furmark again. If the temps are still high then the problem is something else. You could still try changing your thermal paste just to confirm that the thermal paste is not the cause of the problem. |
Already did the best I could. Not changing thermal paste. I think that will be very unlikely and may only lead to 2-3 deg drop and also will void the warranty.
