Old April 24, 2011, 09:51 AM
JD JD is offline
No need to reinstall/repair. It'll "just work".
Now you don't need to get a Black Edition CPU unless you plan to do some major overclocking, however it's likely there won't be much savings anyways by going with a "normal" CPU. As long as it has L3 cache, you'll be fine. Don't bother with the "Athlon II" stuff and some of the lower model Phenom II X4's as they lack this.
It really depends on your budget though. A dual-core (Phenom II X2 555) is perfectly fine for gaming since very few games fully utilize 2+ cores anyways, and you could get a GTX460 or HD6790 all within $250. Obviously this is the best-bang-for-buck.
If you have the extra money, I would put it towards a HD6950/GTX560 before the Phenom II X4 955. And well if you want to totally blow your budget, then get the X4 955 as well.
I don't see the reason to buy a 6-core CPU though unless you honestly need that kind of CPU power. It won't do anything for games though.
Grabbing the 1st 2 links I found in the BST section:
You could have it done for $215 (maybe a tad more for shipping costs).
Old April 24, 2011, 09:52 AM
coleo's Avatar
heck i put in a new mb a few months ago win 7 installed all the new drivers and away it went
Old April 24, 2011, 10:14 AM
A x4 955BE $127 at bestdirect free shipping and the zotac gtx560 $220 -$20mir looks like shippings $2 at ncix would be an all around good match.
Gaming FX 8350 stock / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.6GHZ/GA 970 Gaming/ R7 265 1GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old April 24, 2011, 12:26 PM
Coach's Avatar
I would buy both from NCIX and PM the 955BE to the bestdirect price IMO.
As well I personally am long past the idea of a dual core still being good enough. There are plenty of games currently that will yield a substantial and tangible increase from a quad core over a dual. IMHO OP put the idea of a dual core out of your mind especially when the 955BE is only $127!
Hd 6950 ? Hexofire Video Cards 5 March 29, 2011 02:43 AM
Trying to do Eyefinity on 6950 chasiubao Video Cards 1 February 16, 2011 07:58 PM
which 6950? techman95 Video Cards 6 January 29, 2011 04:07 PM
6950 can still be had for ~$267 Coach Video Cards 41 January 8, 2011 05:39 PM
6950 dilemma Coach Video Cards 2 January 5, 2011 01:32 PM
