Old April 17, 2011, 01:20 PM
ultraman7k's Avatar
Default 5850 at full load on desktop??!
Does anyone know why my 5850 is currently showing that it is running at full load on my desktop? Aside from my browser and TweetDeck, I have no other applications open and I have the latest drivers...this is concerning to say the least.
Old April 17, 2011, 02:17 PM
Coffaholic's Avatar
What browser are you using? I had that problem when i first installed FF4 but fixed it once i disabled all the hardware accelerated features ("Options - Advanced - General - Use hardware acceleration when available" is now unchecked). I think it was a problem with the clock switching from 2d to 3d mode and it getting stuck now and again. Also, if you have Overdrive Unlocked in CCC, try locking it again and seeing if that helps.
| Q8400 @ 500x8 w/ Corsair H70 | EP45-UD3R rev1.1 bios F11 | 2x2gb Gskill F2-8000CL5-2GBPQ @ 500Mhz | EVGA 560 Ti @ 960/1920/2150 | 64gb Patriot Torqx M28 |
| PC P&C 750w Silencer | Soyo 24" DYLM24D6 | Silverstone Fortress FT02B-W with Air Penetrator fans |
Steam \ BFBC2 ID - Coffaholic | RIFT - Coffaholic \ Perspice Shard
Old April 17, 2011, 02:23 PM
There's a problem in the newest drivers where it says there is 100% load/utilization when there isn't, its just a display bug.
Old April 17, 2011, 02:34 PM
x2, one of my cards gets stuck at this frequently in any browser. Not really sure what causes it, but I reboot before I game.
Old April 17, 2011, 03:10 PM
ultraman7k's Avatar
using Chrome, but I rebooted and it seems fine. Just made my eyes bulge haha.
Old April 17, 2011, 04:02 PM
It's one of those perpetual ATI/AMD bugs that they never seem to get around fix. That and the dead green Flash screen.
Old April 17, 2011, 07:55 PM
RMAing my GPU (Asus Radeon 4870 DK TOP 512MB) fixed the green Flash screen (and consequently, a black screen for playing back MP4 issue) for me... Not that I'd suggest that for everyone but apparently hardware problems can cause it.
EDIT: (RMA as in the repaired version didn't have the problem)
Old April 20, 2011, 07:10 PM
Hey I'm getting the same problem with my 5850 (catalyst 11.3)...
Restarting the computer fixes it but it's still really annoying. It seems to randomly kick in (99% usage even on desktop with nothing open like OP) and stay that way unless I reboot.
- Launching games at a snail's pace
- It makes alt tabbing while in game slow as hell
- Even the windows User Account Control messages take a long time to pop up
I would really appreciate if someone could shed some light on why this is happening. I knewwww I would regret buying ATI
Old April 22, 2011, 12:52 PM
I don't think it's a hardware problem. It's mainly really crappy software on the part of AMD and/or Adobe. IT doesn't matter. I no longer use and AMD video card.
Old April 22, 2011, 02:52 PM
JD JD is offline
Have you tried uninstalling the drivers and running Driver Sweeper? Then installing the drivers once it's been wiped out?
84C Full Load normal for 5770 Ref Cooler? NineLives Video Cards 7 March 13, 2011 10:05 AM
HD 4670 - Won't load desktop??? Please help! Bores Easily Video Cards 11 December 30, 2009 02:50 PM
Q9550 + Hyper 212+ HSF = 76c full load... Too high? oblisk CPU's and Motherboards 11 October 29, 2009 10:18 PM
Q6600 24/7 Full Load on Air Dizz Overclocking, Tweaking and Benchmarking 19 September 2, 2008 04:44 PM
Full Load/Temperature Questions Boat Overclocking, Tweaking and Benchmarking 11 November 12, 2007 01:27 AM
