Originally Posted by BrutalGreen are you using realtek onboard sound? cause that is very most likely your problem! the frostbite engine doesn't like realtek, try finding a sound card/usb that is lying around and it should fix this...if you wana make sure this is infact your problem go in device manager and disable all onboard sound devices and check to c if you still get crashes.
P.S. I'm not sure but i think this only occurs in multiplayer if I'm not mistaking |
But yesterday I was able to play fine, but today not. I've been playing battlefield for about a year now.
Maybe it's the SP1??
