Old April 6, 2011, 10:56 PM
Coach's Avatar
Default XFX 6950 2GB v1.2 (reference) still unlockable?
I bought one of these cards and noticed that it is version 1.2. I would like to ask those out there in the know whether or not these cards are still unlockable. Thanks.
Old April 6, 2011, 11:01 PM
Coach's Avatar
just to be real clear I have part number HD-695A-CNFC ver 1.2
Old April 6, 2011, 11:06 PM
good q. it still has dual bios(with the switch) right?
give it a try, with the unlocked 6950 method.
Old April 6, 2011, 11:15 PM
Coach's Avatar
I have yet to open the box... first I wanna do my research before "committing" to buy. My cousin has a XFX 6950 2GB ver 1.0 and it unlocks. My buddy has same card only ver 1.1 and it also unlocks. Somewhere I read that a XFX CSR stated that later versions would be damaged by attempting a flash. Needless to say I would like very much to hear from someone with first hand experience about this.
Old April 6, 2011, 11:19 PM
Coach's Avatar
found it:
Pic is hard to read. It can be found here How to enable additional shaders on Radeon HD 6950 - Page 80 - techPowerUp! Forums post #1979
Old April 6, 2011, 11:24 PM
Any of the new 2GB models coming into the channel likely won't be unlockable. There are still some original reference cards available, though. For example, the Gigabyte card is still available at NCIX in limited quantities. That card was also the only card with a perfect unlock record at the time of a published article by one of the major sites. Techpowerup maybe? Can't remember right now.
Old April 6, 2011, 11:32 PM
Coach's Avatar
In my second post I state that I have a reference part number FYI. I am aware that non reference cards will not unlock. What this thread is talking about is reference cards that are ver 1.2.
FWIW in addition to the XFX card in question I acutally have a Gigabyte 6950 2GB from NCIX and yes it unlocked perfectly.
Old April 6, 2011, 11:47 PM
does unlocking really give you noticeble performance gain?
Old April 7, 2011, 09:01 AM
yup. extra hp under the hood, even at the same clockspeed,will make a difference.
Old April 7, 2011, 10:24 AM
Sorry, I should have been more specific. What I meant was any of the new 2GB reference cards coming into the channel will likely be locked, even with the same part number.
Non-Reference 6950/6970? CMetaphor Video Cards 22 April 8, 2011 04:13 AM
MSI 6950 2gb Twin-Frozr 3...worth it? Socrates_Johnston Video Cards 15 April 7, 2011 09:11 PM
BenQ V2420h + XFX 6950 Prolab Troubleshooting 6 January 31, 2011 01:02 PM
Will the XFX HD 5870 Reference Design OverVolt? Kommandant986 Overclocking, Tweaking and Benchmarking 4 May 3, 2010 03:54 PM
XFX 4890 w/ non-reference cooler (ZSFC) sindraod Video Cards 7 November 20, 2009 07:19 AM
