Old March 28, 2011, 12:18 PM
shayan288's Avatar
My copy is not a Steam copy (I got it from Direct2Drive). And I tried renaming it to Rift.exe because some ppl on various forums said it fixes the flickering problem but it didnt work.
The 288
Q9550 E0 stepping @ 4Ghz
Gigabyte EP45 UD3P
G.Skill pc2 8500 1066mhz RAM
Western Digital 250gb
Antec 1200
XFX HD5970
Steelseries Xai Laser Mouse
Windows 7 Ultimate x64
Old March 28, 2011, 02:07 PM
Did you try Bioshock.exe like someone here recommended?
Old March 28, 2011, 02:33 PM
shayan288's Avatar
Yes, I tried Bioshock.exe and it did not work (screen was still flickering terribly)
The 288
Gigabyte EP45 UD3P
Antec 1200
XFX HD5970
Old March 28, 2011, 07:16 PM
Amarthfea's Avatar
Hey, don't know if you found the Catalyst A.I. setting yet but in case you didn't.
Its under the "Gaming" Tab, 6th down. Then "Catalyst A.I." is the 3rd option down, under "SMOOTHVISION HD: Anisotropic Filtering" with a disable box clearly identified.
~Elysium, I behold your beauty...
Old March 28, 2011, 07:20 PM
TopDogZero's Avatar
Catalyst A.I. can be disabled, first click on preferences button in CCC and change view to Advance then click on gaming tab on left side then 3D Application Settings and you'll see a check box to disable Catalyst A.I. hope this helps.
Edit:
Old March 28, 2011, 08:37 PM
shayan288's Avatar
Edit:
It was already on advanced view, and the stuff that I typed above was all I see for the Catalyst A.I. section.
The 288
Gigabyte EP45 UD3P
Antec 1200
XFX HD5970
Old March 29, 2011, 09:11 AM
Amarthfea's Avatar
CCC version : 11.2
hardware : 4870x2
10.6 With 5970...? Chromey Video Cards 4 June 30, 2010 02:41 PM
2x HD5850 CROSSFIRE or ATI Radeon 5970 2GB GDDR5 Ram Alexanderrazz Video Cards 10 June 28, 2010 06:13 AM
Looking for a review between 5870 crossfire vs 5970 variants Mark Video Cards 4 April 27, 2010 07:27 AM
HIS 4850 ICEQ4 Turbo crossfire or normal HIS 4850 crossfire? lanken123 Video Cards 6 October 7, 2008 09:47 PM
