Old March 26, 2011, 01:27 PM
r0k0's Avatar
Default PhysX Card
Would a 7600GT or 7800GT OC work for PhysX only ?
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
Old March 26, 2011, 01:33 PM
You'll need at least a 260 minimum for good PhysX
Old March 26, 2011, 01:37 PM
MacJunky's Avatar
For games of the future.
For games of the now you can use a 9600 or 9800.
I do not think the drivers even support anything older than 8x00 series anyway.
Old March 26, 2011, 02:17 PM
r0k0's Avatar
would a very dirt cheap
nVidia 210 card do the job ?
Main Rig
Canadian Eh ?
Old March 26, 2011, 02:21 PM
My 8800GTX did a great job until i replaced it with a 280. Diddn't even notice a performance difference with Physx really tho....
Death to Apple
Old March 26, 2011, 02:23 PM
lowfat's Avatar
Definitely not. 2 years ago I tried a 9500GT and it still wasn't even close to being good enough.
Old March 26, 2011, 04:39 PM
Mook06's Avatar
also, the 7000 series gpu's have the older shader design that does not allow cuda or physx, must be 8600gt or newer to support i believe
Old March 26, 2011, 04:49 PM
8800/9800 looks to be a minimum.
some games will drop fps with the above if you disable physx on your 5 series nv cards,higher end though. same with 4 series.
Old March 26, 2011, 05:57 PM
KaptCrunch's Avatar
Default ready Nvidia PhysX
here the list
Old March 26, 2011, 06:38 PM
Yeah, not all versions of the 8800 are good at physX, but the 9800 and the GT 240 are the minimum cards I would ever suggest for PhysX. Don't buy anything below that! Also, the GT 260 is the sweet spot where you get a huge jump in physX performance.
Broken card for physx? Fudd Rucker Video Cards 6 December 12, 2010 09:46 PM
Question On a PhysX Card shayan288 Video Cards 13 October 29, 2010 02:26 PM
Dedicated Physx card with main ATI card? NineLives Video Cards 5 June 27, 2010 07:20 PM
[WTB] Physx Card Dadi_oh Buy/Sell & Trade 12 May 6, 2010 11:57 AM
Physx Card NightRain Video Cards 15 July 9, 2009 06:55 AM
