Old March 21, 2011, 11:23 AM
ZZLEE's Avatar
Could be LCD
whats the specs on the LCD ? Refresh rate ?
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old March 21, 2011, 11:27 AM
Originally Posted by sankukai View Post
I just did a clean system install on a new Seagate 1TB hard drive so the only thing I can think of that could further improve performance is updating my drivers. ATI's 11.1a driver hotfix supposedly fixes a number of performance issues on their radeon 6800 series but I already have their Win7 64-bit CCC 11-2 update installed in my system. I assumed that all prior driver updates/hotfixes would already be included in this package, isn't that right?
If not, then please let me know what other updates/drivers/fixes I should be installing to improve my system performance
thanks
Guys?
Anything else?
Old March 21, 2011, 11:31 AM
Originally Posted by ZZLEE View Post
Could be LCD
TV is a 32" LG LD330 LCD TV, 60hz refresh rate and 1360x768 native resolution
Old March 21, 2011, 12:37 PM
i probably doubt it because of the low res but maybe its the core2 quad bottlenecking?
que the experts to say no chance
Old March 21, 2011, 12:58 PM
what is the gpu and cpu usage when you experience lag?
also did you tried lowering aa/af? does it fix the issue?
might very well be drivers too
Old March 21, 2011, 01:17 PM
no chance. a core2quad is still a powerful unit.
Old March 21, 2011, 02:05 PM
It has to be your drivers go on AMD's forums and ask what drivers will eliminate the stutter.
Old March 21, 2011, 03:44 PM
Bond007's Avatar
I am sticking with what I said at first and agree with all others. Your system should be perfectly capable of nearly all games maxed at your resolution. It must be a software/ driver issue. Try latest driver from AMD. If that doesn't work try the newest driver that is available from the brand of your video card (ex...if you have an ASUS card go to the ASUS site and try their driver).
  #19 (permalink)
Old March 21, 2011, 04:36 PM
thanks
I have a 6850 and I ran into problems after I upgraded to the 11.2 drivers (stutters, freezes, crashes, etc). My problems went away when I uninstalled the ati drivers and then re-installed with the 11.1a hotfix. I've been using the 11.1a ever since. Try that and see if it helps, but make sure to uninstall the currrent drivers first.
I have my 6850 overclocked to 6870 speeds and it plays those games just fine (although with some lag on metro) at 1650x1080, so your 6870 should be just fine for your resolution.
Thinking of getting a new monitor after I get my new gfx card grifter11 Display Units 3 November 1, 2010 12:01 AM
Good, Cheap GFX Card? deathsupport Video Cards 12 August 23, 2010 12:12 PM
help with gfx card. timidestemu Video Cards 12 May 14, 2010 06:59 PM
[WTB] WTB/WTTF Any GFX Card! Cowboy Buy/Sell & Trade 8 October 17, 2009 09:57 AM
GFX card for an Antec Minuet Mr. Gruntsworthy HTPC Systems & Software 20 March 26, 2009 09:04 AM
